Question about Child Craft 5900 Heirloom Pine
The rails to hold up the sides - Child Craft 5900 Heirloom Pine
  • 340 Answers
You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware for many cribs.
Posted on Nov 18, 2009
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
Leak at fuel rail on volvo 960
take a lead from your battery .then reach under the inlet manifold. remove the 10mm bolt and copper washers one each side of that bolt. that is the feed line from your fuel rail to the cold start injector .now remove each of the ten mil bolts holding on your fuel rail . now remove the clips holding the injectors to your fuel rail. place some clothes under the fuel rail and lift off . care needed due to fuel wear eye protection due to fuel pressure..
Dec 01, 2013 | 1995 Volvo 960
Drivers side window off track on 99 monte carlo
take off inside panel roll down window while you hold window with hand if you look on bottom rail you will see a plastic piece that holds window on bottom rail that broken part will let your window move off bottom rail that lifts window thus it will come off track its a cheap part that you can buy and fix your window
Feb 15, 2013 | 1999 Chevrolet Monte Carlo
Fuel rail in a 1997 3.8L pontiac firebird
to remove fuel rail you need to remove 2 mounting bolts holding fuel rail in place.
Aug 27, 2012 | Pontiac Firebird Cars & Trucks
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
How to remove fuel injector #3 diagram
Hi, the picture shown is the driver's side of the engine. Go to the passenger's side and remove the 2 similar screws holding the fuel rail. Disconnect all of the injector connectors on that side. Raise the rail up carefully until the injectors come free from the manifold. #3 is third back from the front of the engine. Twist and pull it out of the fitting on the rail. Oil the oring on the new injector and twist it in. Oil all of the lower orings and slip the injectors back into the manifold. Replace the 2 fuel rail bolts and reconnect the injectors. Please let me know if you have questions, and thanks for using FixYa.
Jul 09, 2011 | 1999 Ford Expedition
I am trying to disassemble a electrolux 2100. I have looked at instructions given by Chemist 1961 and others. On the side, I have removed the rubber covers over the plastic rails but I can't remove the...
There's a tab at the back of the rail that needs to be released. Turn the vacuum on it's side, slip the tip of a standard screwdrive into the space between the rail and the back of the vacuum, and tap lightly with a hammer. Tap toward the front of the vacuum a few times until the rail is far enough forward to be slid out fairly easily. As a side note, the rubber covers do not need to be removed to do this.
May 08, 2011 | Electrolux Lux 5500 Canister Vacuum
I have an older FR350 nailer. The coil return spring broke. I have the replacement and want to fix it. Do I have to take the whole nail guid assembly off to replace this part!
The best way to replace the spring is to remove the rails entirely. Take closeup photos of the gun from all sides with your digital camera or camera phone to help you with placement of all screws. You will need small clamp, small vicegrips and paperclip or piece of soft wire with small hook bent on one end to temp hold spring in place. With rails in hand check if pusher will slide out front of rails (some rails have a small casting preventing pusher from coming out front ~ remove tailpiece and slide out back ). Locate small screw /nut holding spring in place (keep this side of rails facing you). With new spring in place slide pusher into rails until you can catch the eye of the spring with bent wire at front of rails. While holding wire with vicegrip pull back pusher a few inches and clamp in place with c-clamp. Pull or let in bent wire to align eye of spring to attachment hole and install screw (you can leave bent wire in eye and just break off later. With screw attached break off wire and install rails to gun. Check sliding action of pusher before installing bolts at rear of rails. The pusher on some porter cable guns have plastic sliders that easily break with normal use and should be replaced as needed. Good luck.
Feb 08, 2011 | Porter Cable Air Tools & Compressors
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
Crib locks
if you're missing the lock parts from the ends of the side rails(end caps), I was to. I borrowed the cap from the youth bed rail
since when it's configured as a crib, that rail is extra anyway.
when it was time to go with the youth bed I simply put the end
caps back onto the other rail. GOOD LUCK!
Apr 10, 2008 | Childesigns Carrollton Crib
Child Craft 5900 Heirloom Pine Logo
80 people viewed this question
Top Child Craft Baby Gear Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a Child Craft Baby Gear Expert? Answer questions, earn points and help others
