Question about Tascam 2488 Portastudio Multitrack Recorder System
On my Tascam 2488, the Stop, Play and Record buttons have been getting harder and harder to press and activate. Today I can't get them working at all no matter how hard I press. I opened the unit up, but can't even access that area. It looks like I need to remove all the slider keys first, but don't even know how to do that without breaking them. Help??
I just resolved this issue on my own Tascam 2488. The unit does not have a pause button, so it is critical that the record and play buttons work right or else the unit is non-functional. MIne stopped working, so I used "DeoxIT" D-5 contact cleaner. It is the same product that I have used on my electric guitar pots. First, I unplugged the unit and held it on it's side. I used the extension straw to apply a couple of shots per button in the space around each of these buttons. (rev, ff, stop, play, record)
Then, I placed the unit on the floor upside down on a paper towel and walked away. Later, I came back and used the "blow out cake-candles" method to clear any debris from around each button. The unit now works like it is supposed to and the buttons immediately light up when pressed!
Posted on Jul 11, 2011
I got the same problem. Also, the headphone jack on my Tascam 2488 is going bad. Only the right headphone will work most of the time. Anyone know a remedy/ solution for this?
Posted on Nov 23, 2009
Throw it on the floor it should work
Posted on Jan 06, 2010
  • 1 more comment
  • Craig Sutter Dec 30, 2010
    How about DON'T throw it on the floor, and fix it instead... YOU CAN FIX THE BUTTON PROBLEMS, they're not broken, just dirty. It's easy: Spray radio shack contact/control cleaner (the stuff that used to be called tuner control cleaner) liberally into the gaps around the buttons, (yes, right on the top panel, you don't have to take it apart at all). Press the buttons repeatedly, let sit a while, then blow compressed air into the same gaps, OR use a vacuum cleaner, to pull out excess fluid. (which is by now just white mineral oil). Your play, stop, rew, ff, rec buttons will work like new. I've done it to both of my 2488's and saved them from the junk heap. Sorry don't know about any other issues, never had them.
    Reply
  • The Joneses Jul 09, 2011
    Thumbs up about the radio shack contact/control cleaner. I tried this recently on my Tascam 2488 and it worked! This info easily saved me $100+, As I was about to take the unit into the repair shop. Who probably would have done the same thing, while telling me that they had to replace the play button or worse the mother board. Great tip! This tidbit of information is much appreciated.
    Thanks
  • thisdoug87 Jul 11, 2011
    There is no "pause" button for recording, so it is crutial that the record, stop and play buttons work well. I was using the Tascam 2488 and these buttons stopped working, so I was very glad to find this information. I used "DeoxIT" brand contact cleaner-D5. It is the same product I have used on electric guitar pots. It comes with an extension straw like on a can of wd-40. I unplugged the unit and held it on it's side. Then I applied the spray around the rew, ff, stop, play and record buttons into their cracks. I then placed the unit upsided down on a paper towel and walked away. When I came back, I blew out the space around each button using the "blow out cake-candle" method. Now the unit works properly and each button functions crisply again.
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Having problems recording and playing back tascam dc-02 cf
I'm assuming you are plugging the left and right outputs from the karaoke machine into input A and B of the Tascam to record the stereo output of the Karioke. The Tascam works with mono only (you recreate the stereo mix at mixdown or when bouncing mono tracks together with the panning set). Therefore you should be assigning inputs A and B separately. You could press assign A and then the record button above track 1 and then press assign B and the record button above track 2. Then arm tracks 1 and 2 (by pressing record above each). When you then press play and record together you'll record input A onto track 1 and input B onto track 2.
Hope this helps.
bd.
Mar 25, 2009 | Tascam 2488 Portastudio Multitrack...
Recording midi player
Yes. You can record the midi output to a track using bounce mode.
With you midi (or smf) file loaded into the midi tone generator,
press shift-bounce to enter bounce mode. Then arm a track for recording. Turn the fader up for that track, the master fader and the fader for the midi tone generator. Make sure than all other track faders are down or the tracks are muted (or empty) and press play and record. The midi song will be recorded to the track in real time. Just press 'stop' when done and exit bounce mode (by pressing the bounce button again).
bd.
Jan 12, 2009 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Aug 21, 2008 | Tascam 2488 Portastudio Multitrack...
To record the eight inputs onto 8 separate tracks at once simply plug your mics or other audio sources into the mic inputs (only 4 can be powered, A-E) and then assign each input to a separate track by pressing the input button which corresponds to one input and then the select button for the desired target track at the same time. Do this for all eight inputs and their target tracks. Then arm all eight tracks to record by pressing the record buttons on each (the red lights will come on). Then when you press play and record in the transport section (or use punch operations) you will record all eight inputs to all eight tracks at the same time.
Good luck.
bd.
Jul 06, 2008 | Tascam 2488 Portastudio Multitrack...
Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
649 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
