Question about Car Audio & Video
How to bridge
How do u bridge it properly?
    Problem Solver:
  • 8 Answers
The amp must say bridgeable if not you will blow something the speaker of alot of fuses je
Posted on Nov 17, 2009
How do I adjust bridge thickness on ice o matic
Adjust the Timed freeze. The freeze timer is an adjustable timer used to control the ice bridge thickness. The freeze timer is factory set but may need to be adjusted upon initial start up of the machine. When time is added to the freeze timer the length of the freeze cycle is increased, therefore the ice bridge thickness is increased. When time is removed from the timer, the freeze is shorted and the ice bridge thickness is decreased. The freeze timer can be adjusted by sliding one or more switches to either the ON or OFF position to 1/8'' ( 3mm ). If bridge is too thick remove enough time from the timer to achieve proper thickness. If bridge is to thine add enough time to timer to achieve proper thickness.
NOTE: The freeze timer on ECP models is located on the circuit board. It operates and is adjusted as described above. Now if you have had this machine for awhile and it was making the right bridge thickness and is now making thinner ice i would look at the purge valve to make sure it is not letting water seep out of the sump tray during freeze cycle this will cause the sump tray to keep filling up with water and will cause thin ice.
Sep 15, 2014 | Kitchen Appliances - Others
Hi there i have just purchased two newer model type r alpine subs and a week ago i got a great deal on a rockford fosgate 800 a2 amplifier. The amp has two outputs and don't know exactly what ohms are at...
if you bridge it i believe you run at 4 ohms instead of 8 even if the subs are wired together i would not bridge it for fear of blowing the subs. if you where to bridge it it would be the left channel on one terminal and the right on the opposite terminal. but i highly advise against bridging it as they are wired together. its running at the proper impedence NOT bridged.
Mar 14, 2011 | Car Audio & Video
Reset bridge to different router without the disk.
Follow these steps :
•1
Reset the bridge. Accomplish this by manually disconnecting the power source from the wall or the back of the bridge. Leave it disconnected for 30 seconds to a minute so that the software contained therein can fully reset. Reconnect the bridge and wait two to three minutes until the network is back up and running again. In many cases, a simple reset can solve your network-related bridge problems.
•2
Ascertain whether there is network activity on your computers. Accomplish this by looking at the back of each computer at the network card. There should be two lights next to your Ethernet port--at least one of these lights should be completely lit without flickering. This indicates that the network card in the machine is operational and ready to receive a signal, eliminating that as a possible problem source.
•3
Move the bridge to a different location to determine whether interference is preventing the network computers from receiving a proper signal. If possible, relocate the bridge to the same room in which the computers are located and try to reset the connection again.
•4
Determine whether the bridge has failed altogether or whether the wireless signal from the bridge has failed. Accomplish this by physically connecting the computers to the wireless bridge through the use of Ethernet cables. If this restores network connectivity, you know that the only problem with the bridge is the wireless signal emission.
Oct 01, 2010 | Computers & Internet
Inotation
Try this site to find info:http://www.stewmac.com/freeinfo/Bridges.html Also:http://www.fretnotguitarrepair.com/Electric_Guitar_Intonation.htm Hope this helps.
Nov 16, 2009 | Music
How to configure it for point to point network
I'm assuming you have two of these.
Configure one as an access point. Choose a frequency channel, an SSID, a power setting, and an encryption method and password. Set its administrative password. Give it an IP address in the proper range of your LAN, and attach it to your LAN switch. Point it properly.
Configure the other as a bridge or a bridge-router, as you require. Tell it what SSID to find, set its power setting, and give it the same encryption method and password. Set its administrative password. Give it a different IP address in the proper range of your access point's LAN. If you configure it as a bridge-router, configure its own LAN side as you wish. Point it at the remote access point, and within about 30 seconds it should pick up on the signal and you will have a point-to-point network.
Sep 03, 2009 | EnGenius EOC-3220 EXT (EOC3220EXT)
No internet connection
bridges sometimes use mac cloning to clone the device that is attached to it. go into bridges config page and disable this feature and also make sure to select dhcp since bridges will also use a static ip as well. i just hope this helps alittle. i dont have your exact model of bridge here so if you can comment on it i can get back to you and try to help further
Feb 05, 2009 | HP Computers & Internet
I have a logitech cctc system but when i plug in the usb device it states there is a problem with the powerline bridge driver and states its not compatable with vista but logitech states it is compatable...
You might have a 64-bit Windows installed. The drivers on the CD are only for 32-bit windows. Download and install the latest drivers from Logitech website (http://www.wilife.com/Support/Downloads.aspx), which includes the 32-bit and 64-bit versions. Hope this helps !
Jan 06, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Low ohm light on with now RCA's or speaker wires attached? What is going on???? Sound is crap it was working fine for the last year ????????
ohms are impedance or the amount of current being blocked through the line. The lower the ohms the less resistance. Speakers run at a certain ohm (or at least are recommended to run at). Have you bridged your amp? Usually when you bridge your amp it lowers the ohms by half. You may have damaged something, especially if you bridged your amp and didn't bridge it properly.
Jan 31, 2008 | Jl Audio 450/4 Car Audio Amplifier
My Kenwood 800watt amplifier
Sounds like you have overloaded your amp. When you bridge you MUST make sure that you still have the proper speaker load. One 4 ohm speaker on one channel is fine, but when you bridge that same 4 ohm speaker, it gives you a 2 ohm load on each of the two channels that are now bridged. If you made the mistake of wiring two 4 ohm speakers in parallel (plus to plus and minus to minus) then when you bridge you will be driving a one ohm load on each channel. This is very close to a dead short. Stop using your amp at once until you get your speaker load correct. This will damage your amp and it will cause you to have to go to a repair shop to fix it. DO NOT RUN YOUR AMP ANYMORE UNTIL YOU FIX THIS. Good luck.
Jan 22, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
