Ethernet controller device
My ethernet controller device is not working properly or windows doesn't seem to recognize the device
    Guru:
  • 1,738 Answers
Try a external device sounds like you card is bad.
Posted on Nov 16, 2009
Not detect ethernet controller for dell optiplex 210L i looking for the driver
You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
Jul 22, 2011 | Computers & Internet
Acer x1300 - reinstalled vista and have three yellow warnings in device manager: Coprocessor, Ethernet controller, sm bus controller? How do I fix?
Easiest way would be to use a seperate computer and download the drivers onto a usb stick and use that to install the drivers. You can't download straight to your computer since your Internet won't work (Ethernet Controller isn't installed) You can also burn a CD if a USB doesn't work.
You can get the drivers from here.
http://driverscollection.com/?H=Aspire%20X1300&By=ACER&SS=Windows%20Vista
Jun 05, 2011 | Computers & Internet
Nexxtech ethernet adapter USB to ethernet port. Installation CD says good for windows 98SE and up. I have Wind 98 SE. Will not recognize under windows 2000. The inside paper work also says for...
Hi if you use win98 go to control panel and click add hardware, follow the wizzard and it should work or install the drivers connect device and restart your pc. If the problem stay on let me know regards
Aug 27, 2010 | Computers & Internet
Need instruction on ethernet adapter
first:
there's no specific network card you should get, although you probably may want to make sure you get one that support fast ethernet and gigabit ethernet. make sure also is pci card (most of them are), the other part depends on your budget, netgear, linksys, dlinks are all great brands but the one you pick doesn't have to be.
check some options here
second:
this is how to install a nic card (network adapter / network card)
Installing Network Card
  • First step is to read the users guide and familiarize yourself with the new card.
  • Power down PC and remove the AC power cord.
  • Open the computer case.
  • Find an available Peripheral Component Interconnect (PCI) slot on the motherboard and remove slot insert if one exists.
  • Carefully remove the network card from its static-proof plastic envelope, and slide it into the slot.
    • Seat the card in the slot firmly with gentle pressure along the length of the card, especially right about the slot itself.
    • Snugly, screw the card to the computer frame, but do not over tighten.
  • Close the computer case.
  • Plug your computer in and power it up.
2Follow this procedure to verify Windows XP recognizes the new card.
  • Click Start, then click Control Panel.
  • In Category View (vs. Classic View) click Performance and Maintenance.
  • Click "System" icon at bottom of window.
  • Click the Hardware tab.
  • Click the Device Manager button.
  • Double-click Network Adapters.
    • Beneath it should appear the name of your Ethernet card.
  • Next, double click the name of your Ethernet adapter.
    • If the text in the "Device Status" box says "This device is working properly.", then you successfully installed the card and are finished.
    • If the text in the "Device status" box doesn't say "This device is working properly.", then write down on a piece of paper what it says and continue with next step.
Dec 25, 2009 | Dell Ethernet Card Network Adapter
All USB ports on my emachines T6542 do not work
try to see the BIOS SET UP if the USB port are in enbled status..
if its not,, enabled them...
and see the connection of the USB port into your motherboard if it connect properly..
Oct 27, 2009 | E-Machines eMachines Desktop PC
Code 10 error loading audio driver for wxp. System does not recognize audio hardware.
this is any suggestion i have for u :)
install your sound driver manually.
go to control panel -->doble click system->click device manager->right click the sound device, update the driver then..
note :
(check the ethernet controller is that working properly?.. if not u need to update or reinstall the device first before update/reinstall any sound device)
good luck 4 u
Sep 27, 2009 | Microsoft Windows XP Professional
Windows XP Drivers
You need to download and install all the drivers to recognize those hardwares !
You can download it from here :
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_1501&os=WW1&osl=en&catid=&impid
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 08, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
