Related Tags:
This problem should be removed because:
Problem with Samsung LN-T4665F 46 in. LCD Television
lcd, picture not showing up
when i turn the LCD on the picture comes up for a couple of seconds then it turns dark but you can still hear the sounds...no picture of anything
Solutions (5)
Best Solution
We may neet to begin contacting the attourney general. Seriously we may all have to write letters. I am willing to organize this if others post a willingness to engage in this process. Samsug customer service told me that what people report on the internet has nothing to do with Samsung. I explained that I was not wanting to report to the internet, that I was calling to report my number to them. It took some arm twisting to get her to give me a contact on who to report the problem too. They won't listen to internet blogs and I don't blame them for that. However, I was reporting directly to Samsung and they did not want that too happen either. That is not ok. We need to get the attourney general involved. Who is with me?
Im in. No TV should only last 1-3 years !!!!!!!
This may be the backlights and or the backlights power supply is in failure, or the drive board is not working properly.
The set will have to be serviced. In some models, the backlights are not replaceable. In this case they would have to replace the screen. The service center can tell you for your particular model.
If you want to verify the backlights, in a darkened room shine a flashlight at an angle in to the screen while the set is running. Look at various angles to see if you can see an image. If you can see a proper image, this means that the backlights and or the power supply for the back lights has died.
Jerry G.
I am in! Mine just started doing it today. got home from work turned on the LN-T4665F no picture just a hum and shut down. Not happy about this i love that tv. Products need to be tested better before sold on the market, or cheaper if their only gonna last a quarter of the life expectancy.
i am with you, I have the same problem! let me know what I can do to help your law suit.
I too am having the same problem with my Samsung 46" LCD Hd TV, model LNT4665FX/XAA Version SX06. It is very slow to power up and is getting worse. The screen at times will show vertical lines of color and needs to be powered down and then back on. From what I've read the problem will only get worse. The cause seems to be bad capacitors installed in the set. I'm posting a link to a video that will show you step by step how to fix this problem yourself and save you a lot of money in the process. I've not done this yet myself but I will be doing this this weekend when I can get to a Radio Shack to buy the replacement capacitors. It's funny how when you contact Samsung about this they've of course never heard of this problem and it just so happens that this issue comes about most of the time right after the 1 yr manufacturers warrenty has expired. Samsung has lost another costomer here too more because of the way they continue to deny the problem exists. If I can help in your law suit please email me. The link to repair... http://www.consumeraffairs.com/news04/20... .....Good luck
Picture will not stay in after 4 seconds of...
after that it goes dark and I still hear great sound and when I turn the channel the station comes and goes dark after 4 seconds with every...
toshiba regza 42" lcd sound but no video
When I turn the tv on I have perfect video and sound then after a couple of minutes the screen goes a dark grey color but the sound...
LG DU-42PX12X Plasma, picture startes flashing...
Have a 42 in LG Plasma tv on my wall.. Couple of days ago the picture started "flashing" brightly, then all of a sudden the pictue...
Samsung lnt 4665fx major problem..
Hi having problems with my 46inch lnt 4665fx lcd tv.Sometimes when i put it on, the sound comes on and the picture comes on for a...
I was watching TV and
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it...
Add Your Solution
samsung 46
there is a vertical line on the left side of TV screen when switch on.....after about 20 minutes it goes away. Help
Fix-O-Meter
6,546
6,546 people viewed this problem
- 15 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Samsung Flat Panel Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
