Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
When i try to download java an error pops and and says it cannot find the path specified
    Guru:
  • 1,738 Answers
Shut down your firewall program.
Posted on Nov 16, 2009
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
Have removed java updates and now operating slowly, when i have tried to download java again i am getting error codes 25099 and another error 2753.regutils.dll, think i have unintentionally removed...
Hi! the error it self highlighting "regular uitlity" concept in dll name. there is no problem with automatic java updates, but may be missed connection of updates path, so try think about it there would be no problem at all with java updates and operating system..
Dec 13, 2009 | GPS
Agfa Scanner Problem
You need to re-install the driver.
That should resolve you problem.
Mar 10, 2009 | Agfa SnapScan E50 Flatbed Scanner
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
It says installation error when i want to insert mxit?
This phone isn't very good with Java... try downloading their older versions....
Jan 11, 2009 | Samsung SGH-E370 Cellular Phone
'unable to save file. the system cannot find the path specified'
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
Jun 07, 2008 | Samsung SGH-D600 Cellular Phone
Cannot install/uninstall Java
hi,
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Installing java
Do you set the envirorment variables(Java_home), if it is ,check the path is correct or not.
Delete the ClassPath from environment variables, and set class path in command prompt by typing class PATH=%PATH%;path to java(eg:class PATH=%PATH%;C:\Programfiles\jdk1.6\bin) .
Dec 31, 2007 | Computers & Internet
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
Top ArcMedia Computers & Internet Experts
Computer Links
Alun Cox
Robin Hill
Robin Hill
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
