Drum not turning. pump works but times out ends cycle but doesnt spin. left with wet washing
  • 10,865 Answers
Hello. I can assist you. When your washer will not spin and the motor is not running it is the lid switch, replace it. If the motor is running but it won't spin it is a frozen pump pulley or a broken pump belt.
Good luck with it. Thanks for choosing fixya
Posted on Nov 16, 2009
Water is left in the drum so have to set it to spin again.
as the machine gets older the motor wont spin as fast
water pump solenoid or water level shut off problem
could be a timer issue or the printed control pads
drum clothes overload
May 19, 2016 | Washing Machines
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
My miele wt945s takes in some water after final spin so clothes at bottom of the drum end up wet. Can I stop this happening
There is a problem with the programming of the control board if this is occurring.
All you can do is turn off the water to the machine at the end of the full cycle and then run the spin cycle again to dry out the clothes. Then no water can enter the wash drum.
Otherwise you would need to turn off the water each time before the spin cycle concluded and thus before the machine began adding water again.
Dec 08, 2015 | Miele Washing Machines
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
My Fisher Paykel washing machine works well but seems to need two spins to dry properly all of a sudden, blocked pump?
It can be due to insufficient RPM of the dryer or due to water logging within the drum.
Please check this link for tips:Pump
Check the drive for jamming of the spindle.
Jan 22, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Washing still wet after washing machine cycle. After full cycle the wahing in the machine was still soaking wet
Either the pump is not emptying the machine quickly enough, or the drum is not spinning. This could also be because there is too much water left in the machine. Check that the drain hose is not blocked and that water is draining/pumping out of the machine. A partial blockage will extend the drain period and the machine may not have time to empty the drum...Good luck......Nomess
Apr 18, 2010 | Washing Machines
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have 2 problems with my AEG Lavamat 981. 1. The drum won't empty out. We have tried using the emergency drain and even removed the hose connecting the drum and the pump(at the pump end) but the water...
first if you drum is filling again after wash you may have a faulty hot or cold inlet valve turn water taps of after wash has finished if no water in drum the next day just a matter of isolating which valve it is
your second problem sounds like you have a blockage in the hose coming out of your drum to the water pump may be that missing sock you were looking for hope this helps let me know how you went
Nov 13, 2009 | Audio Players & Recorders
There is still water in my washing machine drum when it is done
Is your drain hose to far down the drain pipe?
Sometimes the water can cyphon back down into the machine if this is the case.
Jun 17, 2009 | Frigidaire FTF2140E King-Size ENERGY STAR
When I use the spin only cycle on my Bosch WAE20260AU front loader it runs the pump for most of the cycle time. It only spins briefly mid cycle and the clothes are still very wet at the end. I do a lot of...
I have the same problem on a Miele W418 washing machine.
Just will not spin at all although the Pump out motor and the rest of the washing cycle all appear to be working.
Jun 15, 2008 | Bosch Washing Machines
24 people viewed this question
jasbo
jasbo
