Question about Garden
I need to put new line on stihl wipper snipper one that you insert through holes not take apart to put line on I know you insert line through holes and turn re arrows, but cannot seem to insert line through the two holes? it breaks up when using
  • 1 more comment
  • admin602 Nov 17, 2009
    My stihl autocut C5-2 Is supposed to be easier to insert line
    but cannot get the gist of it. Instead of taking off the top to wind the line and put line through holes and put together
    You leave top on insert line and wind way arrows are going. cannot seem to do this Do you put line in both wholes to start and then wind?
    only bought this year think 55? Am at work left whipper snipper at home as too hot to put in car and thought I would remember, all I have is what is on the auto cut head C5-2 Thanks
  • Bill
    Bill May 11, 2010
    What model?
  • 203 Answers
SOURCE: I had to put in new fuel pines but may have
The brass nozzle nearest the primer is the return fuel line. The inlet is the other nozzle.
Posted on Nov 29, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my stihl fs36 Whippersnipper continues to flood what is the cause
Your float adjustment in the carb needs to be reset, or there is trash under in inlet valve in the carb.
If the float is set wrong or trash in the inlet valve then that will cause the problem of flooding,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
  • 313 Answers
SOURCE: How do i replace the line in a Stihl whipper
Look on Stilhl web site for downloads to locate the operating instructions which you can download and print off. Possibly in PDF format.
Posted on Jul 25, 2010
needs a carb kit with needle valve $20 at a small engine store
Posted on May 22, 2011
  • 316 Answers
SOURCE: Replace fule line on ryobi wipper snipper I
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers,any comments welcome,thank you. ``
Posted on Feb 19, 2012
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
Need a new wire from throttle trigger to carb
throttle cable, call a Stihl dealer. Part look-ups for Stihl and others are not available online
Aug 28, 2013 | whipper snipper stihl fs 38
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
Mar 30, 2013 | whipper snipper stihl fs 38
Feb 03, 2012 | Ryobi Garden
I Have a stihl fs 38 wipper snipper. I am having trouble setting the carb jets. Can you help me?
Even touching carb jets is the very last resort, if u absolutely have too, turn them closed, b mindful do NOT over turn. Turn jet 1/4 turn and if needed 2nd 1/4 turn. no more than 1/2 turn.
Sep 02, 2011 | Garden
My stil wipper snipper starts and runs but only on low revs.it will not rev up
Most Stihl's are the same...Sounds like you need to adjust your mixture screws on the carby. you will need a small flat blade screwdriver (usually these are supplied with the wipper snipper from new and they have a little arrow on the top), H is for the High speed mixture screw, L is for the Low speed mixture screw. Turn the screws clockwise in until they seat (do NOT tighten!!) then turn them anti-clockwise the recommended amounts of turn on the cover around the holes. Careful not to lean the mixture out too much, but if it is the newer type they have a restictor on the High Speed that stops it at 3/4 of a turn. start it up and hopefully it will fix your problem, if not you will have to take it to a professional. Further info majority of STIHL high and low mixture setting are fine tuned via the respective rev settings , you'll have find out the particular setting from your STIHL dealer(sorry)
Nov 21, 2010 | Garden
Asked to repair a McCulloch wipper snipper model TM251SST+. Found fuel line inside tank perished as well as outside primer bulb. Replaced with new. The petrol does not pump up when primer bulb pressed. I...
the primer bulb has the valves in it ,check the in line fuel filter.take outlet off primerbulb,should pump thru from tank,thru the primerbulb
Jul 11, 2010 | Garden
There are three adjustments to the carbureter of the stihl wipper snipper model F585AV. One being the idle adjustment. one of the other two is the mixture adjustment. Question is, which is the mixture...
Low idle speed is one and high speed screw is the other. The idle screw is usually the one located closest to the throttle plate (closer to engine)
Feb 08, 2010 | Home
How to fit whipper snipper line
Hold the snipper upside down so the petrol leaks onto the kitchen floor. Take 6 metres of line and untangle it eventually. Stick it through the two holes and wind the cord in opposite directions so it jams together and tangles. Stick the unit head back together with two feet of line sticking out each side. Start the trimmer and jump backwards as the line rips itself to pieces. Use it on weeds until line breaks within 20 seconds. Slam the end of the trimmer into the concrete and shout **** fuckey **** ****. Then tear off the head cover and start again. I have done this for years and it never fails. Hope this helps.
Oct 18, 2008 | Garden
Garden Logo
644 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
