Question about Dell Latitude D600 Notebook
Wont power on
When I power the laptop on it flashes then turns itself off..
  • westy1955 Feb 08, 2008
    battery will no longer charge and will no longer switch on i have bought a new power pack from dell is it possible that the battery has colapsed it is only showing 9.8volts this lap top is old so i do not know how old the battery is the last time it did charge it got very hot and after this it never charged again.
  • 520 Answers
Need more info,is it a new comp or quite old,has it just started doing this ,have you just got it and this is what happens.if youve had it for a while check hard disk,can do this by trying to install or repair new system.if only lights flash and nothing comes on screen could be bios flash.something similar happens when you dont register windows and your 30 days are up but it lets you get to logon.
Posted on Jan 10, 2008
My laptop wont turn on it just stays off
Try removing the battery, only connecting the AC Adapter and powering it on. Most likely it will not turn on. If this is the case then it is possible the AC Adapter itself has failed in which case you will need to purchase a replacement.
Prior to buying a replacement, more information might be helpful. Does it beep or do any of the lights flash at all? Or does it simply sit there and make no noise, lights or anything?
Jan 04, 2013 | Coby NBPC1023XPBLK Netbook PC
Toshiba laptop L-555 overheated and now wont come on. one green light flashes on and off when pluged into charger.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 26, 2011 | Computers & Internet
My lapto inspiron 1521 wont turn on and the hard disk LDE does not flashes.
Sep 25, 2011 | Dell Inspiron 1521-JB Notebook
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
Battery was low so put in charger.laptop then turned itself off.been on charge 3 hours,still wont come on.led lights flash 3 times when pressing on button
take the battery out unplug the charger hold down power button for 10 secs replug charger back in with out battery then see if it turns on
Feb 24, 2011 | Computers & Internet
My sharp aquos lc-c3242u turned itself off and now wont turn back on. i plugged it into a different power receptacle and the green light flashes but wont turn on. is there a way to reset the tv, or is...
If power light continuously flashing it means backlight problem. Two possible causes. One, backlight invertor is faulty. Two, but realy rare, one of the CCFL lamps went bad.
Dec 02, 2009 | Sharp Televison & Video
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Tv wont turn on, red flashing light
FLYBACK & HORIZONAL OUTPUT SHORTED
Apr 11, 2009 | RCA 32V524T TV
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Toshiba satellite M30 wont power up...
you are using the wrong charger which is damging the battery or the battery is fulty
May 15, 2007 | Toshiba Satellite M30-S350 Notebook
Dell Latitude D600 Notebook Logo
91 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
