Question about Toshiba e-Studio162D Copier
SHARP MX-3501N: The following Error Code is displayed on our unit. H4-00 Error; Call for Service. I need to reset the code, but do not know how
  • 37 Answers
This error is a fuser unit error. you cannot reset the error code without repairing or replacing the fuser unit.
Posted on Nov 17, 2009
How to clear an service error code on a sharp printer?
try turning the machine off then on. if that doesn't work, from copy mode type # * C * to go into service mode (test: enter a simulation). Clear codes 14, 15, 16, 17. type the number then hit the start key. then CA to reboot, you must try the codes on at a time. Please report what your error code was.
May 29, 2014 | Sharp MX-3501N All-In-One Printer
Code H3-00 / crack in Fusing Unit roller
You should be able to just replace the lower fuser roller if your a technician.
Nov 09, 2017 | Sharp MX-3501N All-In-One Printer
ERROR CODE H5-01
Make sure you get all of the paper out of the machine that's jammed in it. Then you have to clear the H5-01 by doing the following at the machine's control panel:
touch P * C *
14 - then the black and white start button
Execute
Yes
the machine will reboot and it should clear the code as long as the jammed paper was removed!
How To Sharp Copier Printer Scanner Instructions Troubleshooting...
Feb 05, 2014 | Sharp Mx-3501n Color Copier Printer...
Error code reset h5-01
fuser malfunction! check first your fuser unit before ressiting
Jun 22, 2013 | Sharp MX-3501N All-In-One Printer
How to clear error code L4-06 for Sharp Mx-3501N
If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
Feb 08, 2011 | Sharp MX-3501N All-In-One Printer
I got call for service code: h5-01 I already took 3 papers that were jam but still the error code are still there. Please help... Sharp mx-3501n
press these keys
#, *, c, *, or
#, *, c, #
if input correctly copier will ask for simulation code
type in 14 then start
01 then start
if it ask are u sure after inputing 14 then start hit yes or 1 for yes or execute. copier will restart. all will be fine untill the next three jams
Jun 11, 2010 | Sharp MX-3501N All-In-One Printer
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
What is error code f9-00 on sharp mx-3501N
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Thanks,
CF
Jun 25, 2009 | Sharp MX-3501N All-In-One Printer
Toshiba e-Studio162D Copier Logo
451 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
