Question about Compaq Armada 7380DMT (306010-005) PC Notebook
My battery cannot be detectied and when it charges on the external battery charger which is the only place I can charge it it can't hold a charge
    Sergeant:
    Champion:
  • 317 Answers
Could be you need a new battery, this one sounds like the power cells in it are about to go out
Posted on Jan 09, 2008
Not turning on
Be aware that most cameras, when connected to a computer or to a charger won't start up.
Please try to charge the battery (batteries) on an external charger.
But if the charger does not "see" the battery, the battery must be defect.
By "see" I mean, when you place a battery on a charger, the charger will respond with a light, to indicate it has a battery and started the charging process.
Jan 05, 2014 | Canon Cameras
Camileo p10 wont turn on or charge
I had a similar problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger just a USB cable. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Dec 18, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
Problem with mobility scooter
Take the batteries down to a battery shop and have them load tested. Make absolutely sure they are DEEP CYCLE batteries. My 35a\h batteries put out 480 cranking amps. The battery shop can also test your charger. I have two chargers for my scooter the 4amp charger that came built into the chair, and a really nice three stage 5amp external charger. My scooters batteries have two 50amp quick disconnect connectors. I made up an external harness for the 5amp charger with the same connectors. I can now charge up my batteries out of the scooter. They say my built in charger is a 4amp charger, its slow in comparison to the 5amp charger. Batteries are expensive, regular chargers charge at one rate, full speed and can overcharge a battery. A three stage charger is by far way batter on your batteries. When you start to charge a depleted battery it put out full 5amps but as the battery nears being charged the charger backs off the amperage. When the battery is fully charged the charger goes into float mode and put out just enough amperage to maintain the charge. When i'm not using my scooter i keep the batteries connected to this charger. Deep cycle glass mat batteries don't stay charged very long when just sitting around. In about six months a dead battery will sulfate to the point where it will no longer take a charge. That happened to me once and cost me $200, never again will this happen to me. Battery shops are great places they have the instruments to tell you everything you need to know about the batteries. The batteries are the heart of your scooter unless you know there condition all kinds of strange things can happen. To make sure my batteries were good i have them checked against a known good set of batteries. BTW- Cranking amp is measured by putting a load on battery and increasing that load until the voltage falls off. At the point just before that voltage drop they measure the amperage output, that is you're cranking amps
Jun 22, 2012 | Electric Mobility Health & Beauty
Not charging
Here are some troubleshooting ideas:
1) Clean your battery contacts with a pencil eraser, both on the radio and the charger (gently).
2) Have your radio turned off when placed on the charger.
3) Does the light on the charger come on when you place the battery on the charger?
4) Try another battery on the same charger and see if it will charge a different battery.
5) Try the known good battery on this radio and see if the radio functions correctly with a known good battery.
6) Try a different charger with the questionable battery and see if you can get it to charge.
7) Be certain the insert in the BPR40 charger is turned the correct direction for the type of battery you have. When inserted correctly the rails should guide the radio into place, placing the external charge contacts on the radio against the charge contacts of the charger.
8) Check the date code on your battery, if more than 2 years old, replace it.
Best regards.
Oct 05, 2011 | Motorola Mag One BPR40 Two Way Radio
My camera will not charge. I have just bought a new battery as I thought that was the problem, however it still won't hold any charge when it is plugged into the charging dock. What can I do?
this is probably a faulty of the camera charging system. if this was my camera i search on ebay international seller one external charger for your batterie type. you find in ebay 100 models of external charger, so you charge you batterie and the camera goes like new. you can find a new charger with one or twoo new batterie all togheter to 10 euro . this is the better system to not spend a high fixing sum.
ok?? it s not so important if the camera dont charge the important is that the camera goes perfectly. ciao paolo italy
Jun 01, 2010 | Casio Exilim EX-Z1200 Digital Camera
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
Env2 charger wont fit in the hole and wont charge my phone
The issue is the charger port on the ENV2 breaks fairly easily. Thefirst step is to contact your carrier to see if it is covered underwarranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3. You can get an external battery charger to charger the battery separatefrom phone. cost about 25 dollars. Check out the following link forones that are available on ebay. A extra battery is a good idea as well so you can have one charging at all times.
LG VX9100 ENV2 External Battery Chargers
Hope that helps
May 28, 2009 | Verizon Communications enV2 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Charging
The canon powershot s70 comes with an external battery charger. Open the battery door (bottom of the camera, slide it away from the center of the camera body) remove the battery (push the little brown tab and the battery will pop out) and place the battery in the included external battery charger.
Oct 22, 2007 | Canon PowerShot S70 Digital Camera
Open Questions:
The smartest way to keep your business files secured on online cloud backup Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Online Cloud Backup their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Computer Data Backup with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in Business Server Data Backup provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Sep 18, 2018 | VIA Computers & Internet
See all Compaq Armada 7380DMT (306010-005) PC Notebook Questions
Compaq Armada 7380DMT (306010-005) PC Notebook Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
