Question about Timex 48021 Wrist Watch
My timex 48021 wrist watch keeps resetting itself after i changed the battery
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
  • 7 Answers
SOURCE: Resetting Watch
http://www.timex.ca/en/instructions/085Instr.pdf
Posted on Feb 06, 2008
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Posted on Jul 06, 2008
escapement
  • 2334 Answers
SOURCE: watch goes slow when wearing
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Posted on Jan 07, 2009
rellik227
  • 27 Answers
SOURCE: My Timex Expedition wrist watch losing time.
old battery perhaps?
Posted on Feb 06, 2009
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
DATE WONT CHANGE
If you have the crown in the first click position (date set position) the date set wheel is most likely damaged. Otherwise, if it does not change in 24 hours, it is the date wheel itself that is damaged.
This happens in all watches over time, as even quartz watches must technically be serviced every 3-5 years. 90% of manufacturers quote this as the standard service rate for quartz and mechanical watches.
If this watch has sentimental value, and you will want to contact a local Certified Master Horologist or Certified Quartz Technician about replacing the movement. Replacing Timex movements is generally more expensive than purchasing a new watch.
If the watch is still in warranty, you may consider contacting Timex about replacing the watch free of charge at: custserv@timex.com
Feb 04, 2011 | Timex Expedition 43892 Wrist Watch
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
I have an older timex mens wrist watch and I would like to know where I can look to find the model number on it. It is a wind not battery powered. Thank you for your help.
mcdevito75 here, I just took a peak into my own Older Timex watch, even though it"s a ladies the model number was on the movement itself and only a 3 digit number. Since the older Timex watches were mass produced this is all you may have as far as serial numbers go, and Timex did all their own watches so a serial number may only be 3--4--5 digits long. Anyway, double check the entire watch with a magnifier glass for the serial number, then check inside the back cover and movement itself. Here is Timex contact info, 800-448-4639 if needed.
Aug 11, 2010 | Timex Watches
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Changed battery on ironman, watch got wet, now doesn't work
The bad thing about most Timex watches is that once you open them it is very hard to resael them again. The thing is that , the screws are metal, and your trying to tighten them into a plastic back. If you try to tighten them too much you mess up the tap. When the back is first put into the watch there is a very small hole. When they screw them in it's like a wood screw it taps itself in to the back. Once that has been done once it is very hard to keep the same tighteness it started with. Your best bet is to get a watch with a metal screw-on back with a metal casing too. That way you can tourque really hard and make sure the back is tight. If you decide to have the battery changed, make sure they silicon the seal.That's about as much protection agaist water you have with that watch.
Jul 07, 2008 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
The alarm goes off like twice a day ,a lost the manual ,and i don't know how to stop the alarm to go off
Had the same problem on my timex/acqua; after reading a couple suggestions on this site, I held down adjust button at same time as start/stop and it worked after a second or so. Try any 2 buttons at once, one suggestion did 3 at once.
Nov 08, 2007 | Timex 48021 Wrist Watch
Timex 48021 Wrist Watch Logo
267 people viewed this question
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
