Question about Samsung PCL545R 54" Rear Projection Television
2002 model hello i have a problem with getting into the convergance settings. i can actuate the middle settings but can not actuate the upper and lower settings. i adjusted the red and green settings in the middle but cant seem to get to the others? i do have original remote and have tried the #'s 2 4 6 8 while in convergance screen and that doesnt seem to work either.can anyone help with this issue or have some advice. the tv is sweet and would like to get it set before super bowl. thanks again mark s. connecticut
  • mrmark Jan 20, 2008
    thanks ive tried that but wont respond i can make it go left and right buy pressing the bbe button on remote its also a brand new remote from remote hound and is suppose to be the remote that came with the tv thanks
Use the round joystick control on your tv's remote to move left and right to the boxes, then use the channel and volume boxes to adjust.
Posted on Jan 13, 2008
2002 Cadi Deville, can't get any locks to operate with remote or dash push buttons, the remote operates everthing but the locks! When the remote door lock is pressed, lites flash,horn blows locks not.
Power Door Lock Operation
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door, but the rear integration module (RIM), which is the master control for the door lock system, determines when the lock functions are permitted. The RIM receives and examines the requested lock function from the individual door modules, or from the remote function actuator (RFA) via the class 2 serial data circuit. The RIM also examines the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. If the RIM determines that a lock or unlock function is permitted, it sends a class 2 message back to the individual door modules commanding them to perform that Lock or Unlock function.
Power Door Lock Components
The power door lock system consists of the following components:
Driver door lock switch
Passenger front door lock switch
LH rear door lock switch
RH rear door lock switch
LH middle door lock switch (w/ V4U)
RH middle door lock switch (w/ V4U)
Driver door switch assembly (DDSA)
Driver door module (DDM)
Passenger front door module (PDM)
LH rear door module (LRDM)
RH rear door module (RRDM)
Left middle door module (LMDM) (w/ V4U)
Right middle door module (RMDM) (w/ V4U)
Driver door lock actuator
Passenger front door lock actuator
LH rear door lock actuator
RH rear door lock actuator
LH middle door lock actuator (w/V4U)
RH middle door lock actuator (w/ V4U)
Driver door cylinder unlock switch
Rear integration module (RIM)
DRVMDL fuse (10-amp)
PASS MDL fuse (10-amp)
RRDR MDL fuse (10-amp)
Class 2 serial data link
Sep 27, 2016 | 2002 Cadillac Deville
Convergence problem
What model number of Pioneer TV set do you have? There should be a large heat sink or something metal with cooling fins on it where the IC's might be mounted away from you so you will need to look at the other side of the heat sink. Replace those IC's and you will be able or should be able to adjust the set providing you have not tweaked it too much before repairing the problem. Good luck
Feb 11, 2008 | Televison & Video
Replacing 2002 chevy tahoe blend door actuator
Generally,they will be located under the middle of the dash between the blower and the controls...find a service manual for exact location
Mar 08, 2014 | 2002 Chevrolet Tahoe
2002 grand prix. Heater blows cold on passenger side. Driver side and two middle vents blow hot, the other two vents blow cold.
ether the blend door actuator is bad or the climate control module is failing. most likely the blend door actuator. would have to pull most of the under dash out to get to it to replace it. not fun at all.
Nov 04, 2011 | 2002 Pontiac Grand Prix
How many hvac blend door actuators are there in a 2002 chevy silver ado and where are they located. I tried to purchase the part and it gave me an option for upper and bottom actuators. I need to know...
I'm having the same problem with my 00 GMC Sierra. If you do NOT have dual zone climate control, it's just to the passenger side of the transmission hump under the hush panel underneath the dash. 3 screws take off the hush panel, two take off the actuator. One screw on the hush panel is a pain in the **** to get out. I'm still trying to figure out if the "upper" or "lower" is the proper fit for it. If you have dual zone, then one is under the passenger side, and the other is under the driver side. Hope this helps!
Sep 16, 2010 | 2002 Chevrolet Silverado 1500
Toshiba 41h81 green convergence problem
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
RCA HD52W59 Crooked Convergence
Convergence power supply needs to be rebuilt as its no longer available new. You can get the board rebuilt at the following link and its fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 04, 2009 | RCA HD52W59 HDTV Projection Television
In these projection sets, usually the convergence board has failures. These can be some of the IC's and or a number of the capacitors in most cases.
You will have to call the authorized service rep, or a service center that is familiar with your set and has availability of parts for it.
Considering the age of your set, the risk of investing in to an oder set, it may be a better option to consider a new one at this point.
Jerry G.
Aug 31, 2008 | Samsung HCL4715W 47" Rear Projection...
Convergence
you have a samsung? hcl4715... your convergence chips have most likely blown...sorry..
Dec 08, 2007 | Samsung HCL4715W 47" Rear Projection...
Picture problem
Your set is having convergence problems, are the colors messed up in these areas or does it looks normal beside the arc? If the colors are out of line then convergence problems are on the way. Shut down and look at the convergence board for loose solder connections first, Then resistors that needs replacing. Last may have to change Convergence amps.
Sep 10, 2007 | Philips 60PP9202 60" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
