Question about Ovens
Whirlpool gas range model # GS475LEMS0; Oven light won't come on
I have a Whirlpool gas range model # GS475LEMS0 that is 6 years old and the oven light bulb recently burnt out. I replaced it with a new one, buy the light still will not come on. The oven is spotless and the bulb socket looks brand new. What am I missing? Thank you. Tim
  • stroudtim1 Nov 17, 2009
    Thank you. This is very helpful information. Any idea what the best way is to verify if the door switch is good, as I know the new bulb I purchased is good?
  • 464 Answers
If you are sure the bulb you purchased is ok, then I would check the door switch. It is #27 in the attached breakdown, and the part number is: 3196262. Hope this helps. Whirlpool gas range model # GS475LEMS0; Oven light - 250
Posted on Nov 16, 2009
I have a Whirlpool Stove, model SF367PEYQ3. When we turn the oven to 'BAKE', it takes 1-2 minutes to light. When it does light, it lights with a small explosion and we can smell gas. I took up...
We're sorry to hear about your Range. Can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com so we may look into this?
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Jenn Air gas oven (range) model JGS9900CDS01. I have been smelling gas only when the oven is on..It seems to cycle from worse to not so as the oven cooks. My repairman just replaced the igniter...
it's still under warranty for 1 year but by him working on it you could have voided the warranty i would call whoever you bought it from or call the factory and tell them it's under a year old what will you do for me.
Feb 07, 2018 | Frigidaire FGB24S5A Gas Single Oven
I have a whirlpool stove that is gas the display won t work so cannot use oven.
It's likely that the board on which the display is found also contains the control electronics for the oven functions.
If you want to look into replacing this yourself, go to the link below for illustrations of your unit but the page lists several variations beyond the model number you listed so check your literature from your unit to establish which exact unit you have:
Whirlpool range
Sep 16, 2011 | Whirlpool SB160PEE Gas Single Oven
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Loc error message
I unplugged the appliance for an hour and after re-plugging, the problem went away.
Nov 05, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
120 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
