Question about Sanyo SCP-2700 Cell Phone
The USB cable doesn't work w/ my CPU, is there a driver update available?
    Sniper:
  • 102 Answers
Http://www.sprint.com/assets/downloads/windows_xp/executables/Sprint_Mobile_Broadband.msi
The drivers for Sanyo 2700 are here. I'm told you can see the device but there is not any software to guide you through what you are looking at. You are just able to connect via your PC and use your MY COMPUTER folder and it will recognize your phone.
Posted on Jan 21, 2010
No Signal when HDMI connected with TV and cable box
Replace HDMI cable first, then check whether your box works on HDMI out. Try connecting box using other out (USB, VGA, DVI, DP, cable)
Apr 25, 2017 | Sony BRAVIA Televison & Video
Epson lx-300 parallel to usb printing problem
Make sure driver for Parallel to USB adapter is installed properly, this doesn't guarantee that it will work. Suggestion is, check for interface availability for Epson printer if you can change parallel interface at the back of it to USB interface. Call Epson for details and availability.
Sep 21, 2012 | Epson LX Office Equipment & Supplies
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
Instal in XP
Hello, This external hard drive does not need a driver, even in XP. If you're using a desktop, don't connect it to the usb ports in front of your CPU case, instead, connect the usb at the back USB ports, if this doesn't work, try using a shorter USB cable and connect it again at the back.
Jun 19, 2011 | Western Digital Elements powered by WD 320...
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Can't add printers to Mac
Can you install them individually (i.e. connect only one printer with a single cable to the USB port)?  If you can and then connect them both through a USB hub you may be able to see them both in the printer setup and select the one you want when printing.
Jun 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Pinnacle Moviebox Deluxe - Error "USB Device Not Recognized"
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Feb 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
USB CABLE
the printer is designed to work with a parallel cabel connection. usb to parallel conversion cables may or may not work.
now for the second part is, about the driver (visit manufacturers website for updated drivers), usb driver behaves differently compared to parallel drivers as it expects a usb printer connected to a computer. try both drivers. remember, it may or may not work.
Dec 03, 2008 | Argox OS-203 Thermal Label Printer
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Usb ports on monitor
All you have to do is connect the monitor to the CPU using a USB cable in addition to the usual installation ( check the slots available on the monitor for the type of USB cable you need ), then all your USB slots on the monitor will come alive. Its just like a USB extender ( except that this is included in the moniter).
Enjoy
Nov 15, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Sanyo SCP-2700  Cell Phone Logo
1,034 people viewed this question
Top Sanyo Cell Phones Experts
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
