Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Fan works light works but no cooling in either the freezer or refrigerater
  • 5streeter2 May 21, 2008
    Same here. Fan works in back. Lights work inside. Nothing cold. Compressor gets hot; relay not loose. 1 line hot, other is barely cool.
  • Anonymous May 27, 2008
    Fan works light works but no cooling in either the freezer or refrigerater.
    Sergeant:
    Champion:
  • 260 Answers
The fan in the back of frig will run. Try replacing the evaperator fan and if the evaporator fan does not work replace the thermostat.
Posted on Apr 09, 2009
Freezer works great but refrigerat don't cool
No air flow from freezer to refrigerator
bad fan
or iced up try defrosting
Aug 29, 2014 | Refrigerators
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
The refrigerater wont cool
defrost for a few hours
Mar 11, 2010 | Refrigerators
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Jenn-air side by side refrigerater
Make sure the fan is working ,its located behind the freezers back wall.(5 to 7 screws) If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it w/ doors open 12 to 24 hrs this will free up any clogged tubes.Turn it to 4 or 5. Good luck.Let me know.
Len West
Feb 21, 2009 | Refrigerators
Freezer is cold but refrigerator is not?
In new models the freezer also cools the refrigerater with a fan. you have to call a repairman to do this work. he has the equipment to test the fans.
Aug 20, 2008 | GE Refrigerators
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
179 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
