Can you walk me through how to unseat my video card or determine if it is loose?
  • 4 more comments
  • kstockton490 Nov 16, 2009
    mine is the 2nd one but I can only see the blue clip that is supposed to release/secure it but can't see a screw. Is it inside also? I can see screw at top and bottom of the bay doors but...
    I will go look again. Model is Dell Dimension 9150
    dell dimension 9150
  • kstockton490 Nov 17, 2009
    I have the release mechanism which I can open to expose the card but don't know about card retention door releases; I will have to print it out to see if I can understand/get it to work.
    i finally got the card out and put it back in but still got the same message: stop c000021a 0xc0000135 0x00000000 ox00000000. Reseating the graphic card was one of the solutions
    I understand it could also be a driver issue and that I should reinstall it but i can't do that without fully being able to get windows launched could i? I only get as far as windows xp screen and then it turns machine off and gives me the c000021a 0xc0000135 error message
    Guru:
  • 830 Answers
Hello and thank you for using Fixya's services.
First, you need to make sure that the computer is turned off an unplugged from the outlet.
On the back of the case, there are a couple of small screws that will need to be loosened, so that the left hand side of the computer case can slip off. (this varies depending on computer model and brand, please let me know which you have an I can assist more detailed instructions).
Once the screws are off, you can slide the side of the case off. Sometimes it is a little struggle but you will get it off.
Once you get the side off, you will be looking inside of the computer. You need to be grounded when you touch anything inside of your computer as to not cause static electricity on any electronic components. You can do this by touching the metal on the side of the computer case.
Here is the question. Do you have an integrated video graphics card or a PCI slotted graphics card. If you have a integrated video card, it will be located near the top of the computer (back). If it is a PCI slotted, it will be lower, near the bottom of the case (see pictures).
Integrated (onboard) video graphics
PCI Card Video Graphics
f42b091.jpg If the card is integrated (first picture) there is no way to pull it out but you can wiggle it from the front to see if it is loose. Usually, when these go out, it is recommended to purchase a PCI (second picture) and install.
If the video graphics card is like picture number two, then you will see a small screw holding it in place. With a small screw driver, release the screw (you should still be grounded). Once done, pull the video graphics out of the slot and push it back in.
I recommend re-seating it because if you are having problems, this will usually solve in most cases.
Now, put the screw back on, replace the side of the computer, plug the pc in and turn it on.
If you pulled the video graphics out, Windows will read it when you turn on the computer. If it is faulty, then you will have a black screen (as you probably do already) and will need to replace.
If you let me know what problems you are experiencing, I can further assist in troubleshooting.
Posted on Nov 16, 2009
  • 5 more comments
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 16, 2009
    Depending on the model, you may have to release a plistic gage on the back of computer. It should just unhook.
    The arrow shows where the location of screw is.
  • Jennifer DeLaCruz
    Whats the brand and model of your computer?
  • Jennifer DeLaCruz
  • Jennifer DeLaCruz
    The link I provided above will be very helpful and is fully detailed for your model.
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 17, 2009
    Try taking the card out and using the integrated video graphics if there is one.
  • Jennifer DeLaCruz
    Your computer (from what I can see) doesn't have an integrated video graphics card.
    Suggestion: If you have another computer with a PCI video graphics cards, you could pull it, use it in the computer and at least get it to boot up.
  • Jennifer DeLaCruz
    Last resort, if nothing else can be done, is to reformat the computer. You will need your restore or Windows XP CD. Place the CD in the cdrom, start the computer and hit any key, when it tells you to boot from disk.
    Note: This will erase everything on the hard drive but will get your computer back up and running.
    At this point, the only way to save your data is to pull the hard drive and slave it to another computer. The other computer will read it as a seperate drive and you can copy and paste your documents over.
    Note: If when you start your computer, and press F11, it gives you the option to factory restore, then the Windows is on the hard drive and you will not need a restore disc. This usually only applies to computers running Vista (even if it had it before).
    It doesn't sound the a hardware problem. It sounds like the Windows operating system is corrupt, which is why it is "rebooting" over and over and showing the blue screen. So this option may be the way for you to get it back up and running.
Belt stops at slow speeds
Check the walking belt is tensioned correctly.
Remove power from the mach.
Most machines you should be able to slide your hand under belt, only to about the center of your palm or maybe your thumb.
if walking belt tension is correct. make sure the delt has lube on it. Your owners manual will determine what type (wax or silicone) or manufacturer to use.
When inspecting the deck (laminated board under the walking belt, which it slides on top of), check for wear or damage.
Worn decks and belts should both be replaced at the same time.
Beyond a walking belt area issue, check the drive belt under the motor hood. connecting the drive motor to the front roller. try twisting the belt on its axis. about a 30degree deflection would be standard. If this belt is loose, the front roller is loosing its drive.
Sounds primarily like a belt/deck lube or wear issue.
Jan 05, 2013 | Nordic Track Nordictrack Track C3000...
After using my Gateway M 675 prr and now it is not working. The screen is black, the fans are working and the lights are on, just have a black. What can I di?
The Gateway 675 are known for video card problems.You can unseat the card and clean it,then replace the thermal grease.The thermal grease on these get runny under heat and causes the video card to loose contact.Try the grease if that doesn't work the video card will need to be replaced.
Jun 25, 2011 | Gateway M675 Laptop
My pro form 380 stops while I am walking
Either the walk belt is loose or the front roller pully has spun. In order to determine which one, you need to remove the moter cover and watch the drive belt and front roller while you walk, try to stop the belt and see which one stops. If the walk belt stops and the front drive roller keeps turning, then you need to put a couple of turns on the rear allen bolts. If the roller stops when the walk belt stops, see if the drive belt(small one going to the motor) stops as well. If the drive belt turns fine,but the walk belt and the front roller stop, you need to replace the front roller, because the plastic pully that is connected to the roller, is pressed on and cannot be tightened.
Hope this helps
Nov 10, 2010 | Proform 380 Treadmill Walking Belt
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
Colours on monitor are green based. is the built-in video card shot?how do i determine the exact motherboard in this unit?
first see if it does this on other monitors and if it does then there is either a loose connection, a busted prong on the vga wire or the video card may not be seated properly if it is a card and not built into the motherboard. the motherboard should have a sticker that gives you the name and model of the motherboard
Jan 24, 2010 | Dell Dimension E521 PC Desktop
How do i unseat my video card?
It is simpe to figure out it's the one with the cable connected to the moniter follow it to your computer and look at the plug on the moniter and you will know which one to remove and reinstall. most likely the card came loose from a kick of the foot.
Nov 16, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Tyan s2720 was working fine. cleaned fans and fiters then when I tried to boot up no bios and 7 beeps pause 7 beeps pause 7 beeps etc...
Hi:
Check and see if somehow your video card came unseated from the motherboard. sometimes just moving a tower around can pop them loose.
Nov 12, 2009 | Tyan Thunder i7500 Pro S2721UGN...
I moved my computer to the next room, now the moniter comes on briefly and gives a no signal messages, was working fine
I know this sounds hokey, but check the monitor cable at both ends. Where it plugs into the computer, and where it connects to the monitor. Sometimes the cable connected to the monitor can get pulled just enough to make it loose connection but it will still physically look connected.
Another thing to check is the cable itself. Disconnect the end that's connected to the computer and look at it. If it's a VGA connector make sure you havent bent any pins on the cable during the move.
Something else that comes to mind is if the computer has a dedicated video card. It is possible that the video card could have come unseated from the motherboard durning the move. It doesnt take much really. Carefully take the cover off the case and press down on the top of the video card firmly. It may be necessary to completely remove the card and put it back in.
Hope this Helps
Oct 26, 2009 | E-Machines eMachines Desktop PC
Power supply problem
The blinking amber on a Dell usually means 1 of 2 things. Either it is a video card which has either come unseated, or went bad [most likely in your described case] or bad or unseated RAM. If reseating your video card does not fix problem then it will need to be replaced. Hope this helps & please rate my solution fixya. Thanks.
Feb 04, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
LG StudioWorks 700s Monitor NO SIGNAL
First of all I would check your video card. Do you have another monitor that works fine? If so I would hook the good monitor to your video card and see if you are getting a signal. If you still do not have a signal in the good monitor there is something wrong with your connection on your video card. Check the connector on your video card if it wiggles alot then it has come loose from the card. Best option here is to buy a new video card. If you feel that the connector is seated flush and does not move. Then you might want to look at two things. Either your monitor is not working properly or there maybe a piece of hardware that has come loose or unseated in your computer case. Try this and if you have problems feel free to contact me.
Sep 20, 2007 | LG Studioworks 700S 17" CRT Monitor
53 people viewed this question
k24674
jasbo
jasbo
