Question about Heavy Machinery
Stihl chain saw ms 290
Chain saw will not start. the rope starter will not pull , there is much resistance to pull and start. i have had the recoil off and there is no problem there. when i removed the spark plug the rope will pull with no resistance
  • graham_chin
    graham_chin Jun 30, 2012
    Did you find a solution to fix it .I have same problem
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
stug_57u
  • 99 Answers
SOURCE: cant find serial number on stihl chain saw ms 290
If the silver rating label is still on the safety brake lever, it should be on there. If not, look at teh housing to the left of the exhaust by the 'teeth' on the body, or on the housing below the exhaust. It is normally stamped into the plastic.
Posted on Oct 26, 2008
  • 6 Answers
SOURCE: Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
Posted on May 23, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Stihl ms 290
That sure is an MS290 in the picture, alright. If you have a question about it though, feel free to voice it. Or text it here if you wish. Fantastic!!
Jul 03, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
I can't tighten the chain on my stihl ms 251 chain saw
Pull the side cover and check for a broken or misaligned chain tensioner. I assume that you have loosened the bar nut on the side cover before attempting to adjust the chain tension. The methiod varies depending on whether your model has the side chain tensioner or the quick chain tensioner.
Dec 08, 2013 | Stihl 029 039 Ms 290 310 390 Chain...
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
How does the recoil spring,waher,2 hairpins pins,dog footand rope pulley get reassembeled?
the rope rotor will go on first, then the washer goes on, put the dogs in then put the spring on. insert the rope into the rotor, wind it up, feed the rope through the starter cover, carefully allow the rotor to wind in the rope a ways then put the handle on.
Dec 20, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Heavy Machinery Logo
135 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
