Question about LG Xenon GR500 Cell Phone
How to synch gr500 using bluetooth - LG Xenon GR500 Cell Phone
  • vgambrell Nov 20, 2009
    Well connecting via bluetooth is not the issue, actually getting teh unit to synch is, It does not work with file transfer ot LG PCSuite II
    Problem Solver:
  • 6 Answers
Go to the settings spot and then hit bluetooth and then go to my devices and select new device and you may have to insert code if possible
Posted on Nov 18, 2009
Do you try to sync a headset plugged in or unplugged
When synching your headset, you want to have it unplugged.
Make sure you turn on your headset before synching.
Go into your PS3 settings and under the bluetooth option, select the auto-detect.
Your PS3 should find the headset and identify it.
May 07, 2011 | Mad Catz Bluetooth Headset for PlayStation...
I have the lg xenon gr500 and it has wi-fi capabilities, but i dont know how to use it? and i cant find it in the settings?
the LG Xenon doesn't have wifi/wlan support. It has bluetooth so you can pair it with a computer and exchange data.
Sep 01, 2010 | LG Xenon GR500 Cell Phone
Is there a special setting needed for the LG Xenon GR500 when using a bluetooth?
no just turn on bluetooth pair it with what ever device enter passcode (should be 0000) and let it connect
Apr 19, 2010 | LG Xenon GR500 Cell Phone
Lg xenon will not connect to bluetooth with my eclipse cd5030 stereo unit
u will need to contact the bluetooth manufactur because most wiresless carriers do not support bluetooth
Feb 22, 2010 | LG Xenon GR500 Cell Phone
When turning on my car my parrot starts calling on its own
Some of the auto synch in relation with software troubles or simply the numbers of contacts can be the trouble.
I do not remember that blackberry used an auto synch at the begining, then for me it seem to be complicated to resolv, cause not specialy and easier trouble to resolv.
The type of synchro via bluetooth may be the trouble between both devices.
You can simply pair the phone via the specific menu without synch and send the contact one by one via object push with Bluetooth.
Feb 01, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Palm TX won't synch with Vista
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Apr 16, 2009 | Intel Palm Tx Handheld
Blinking lights no response
I was able to fix this same problem by doing a hard reset, and re-synching with my computer.
To do a hard reset, press the power button and the two center buttons, all at the same time. Hold them down for about 10 seconds - when you let go, the tablet will start trying to synch again. Once you go through the synching steps again, everything should work properly.
Jan 10, 2009 | Wacom (PTZ930AC) Graphic Tablet
Bluetooth synching of a toyota prius and a treo
i had the same problem with a palm 700wx and the new pre try using 1111 as the code it worked for me
Oct 10, 2008 | 2007 Toyota Prius
Pairing tungsten t3 with newer cell phones
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
Oct 01, 2008 | Palm Tungsten T3 Handheld
Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Dec 22, 2007 | Motorola Mobility H550 - Bluetooth Headset...
LG Xenon GR500 Cell Phone Logo
445 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
