Question about Whirlpool AD50USS Dehumidifier
Whirlpool 50 pint dehumidifier
Starts to run, then begins screeching and smells like something is hot or burning...then shuts off
  • 828 Answers
SOURCE: 2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Posted on Jun 29, 2008
SOURCE: Fedders 65 Pint Dehumidifier Fan Problem
I have the same problem. The fan motor bearings are bad on mine. You can get a new fan motor at Appliance Factory Phone number 1-800-955-7075. $44.95 + shipping.
Posted on Jul 17, 2008
  • 441 Answers
SOURCE: Dehumidifier freezing up
it can be fixed but not economically, I would hold onto the unit the new ones are not good at all,
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
Try cleaning the filter first. Pull it out and then wash it with water and let it dry overnight. Then clean the spigot/nozzle which fills the pan. This often becomes clogged with dust or debris or even insect webs. Once you wipe the nozzle with a rag, really clean it well with a finger. You should feel the rubber gasket at the end of the nozzle with your finger.
Likely the fill nozzle was just clogged so water drips along the top and down the sides of the pan instead of into it.
Good luck.
Posted on Oct 08, 2009
  • 43501 Answers
SOURCE: Whirlpool/Gold/Energy Star-Dehumidifier model:
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
Posted on May 18, 2010
0 characters
1 Points
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
I have a whirlpool dehumidifier (AD75UST0) and it appears to be 'dead'. is there a fuse or a reset?
No. I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. My unit slowly got less and less efficient, then it "stopped" coming on as if it was not working. Upon disassemble and inspection I found fan was no longer spinning. It tries to start then (actually the condenser coils begin to freeze, but no Fan) then it shuts down within 30 sec or so.
I am going to try a replacement Fan and fan start Capacitor (always replace in pairs).
Aug 19, 2011 | Whirlpool 75-Pint Dehumidifier
Crosley dehumidifier does not collect water.
May 13, 2010 | Crosley 40-pint Dehumidifier
The fan inside is having a hard time rotating...starting to smell. what gives?
If the fan motor is quite hot to the touch when it is running and the smell is like something burning and the fan blade isn't rubbing on the housing then the fan motor bearing are most likely worn out. If that is the case then the fan motor is bad and needs to be replaced.
Nov 17, 2009 | LG LHD65EBL Dehumidifier
Burning smell from dehumidifer
Well is your filter clean!!!! is it over working it 30 pint 400sqft 50 pint 1000sqft 65 pint 1300 sqft. hope this helps.
Jul 19, 2009 | Whirlpool AD25BSR Dehumidifier
Dehumidifier won't shut off
Well your dehumidifer runs constantly. My guess seeing how you bought a 30 pint per 24 hrs. Your house better be 400sqft. It is under sized and humidity need to be 30/50 percent to stop mold growth. It cant keep up its two small 50 pint are for 1000sqft 65 pint is 1300sqft. Upgrade now!!!!!
Dec 29, 2008 | LG DH30 GoldStar Dehumidifier
Sunbeam 50-pint dehumidifier
That's pretty normal. Most of these portable units blow quite a bit of heat.
May 26, 2008 | Maytag M3DH30B2A Dehumidifier
Lifeguard, there are generally no user accessible safety items in dehumidifiers. You are likely describing the start relay which is used to 'boost' the compressor on starting. Jumping it will not help you. It sounds like the compressor is defective. Economically, there is no justification for servicing these units unless they require refrigerant gas or if the fan motor has seized, something you can readily determine. If you don't hear the compressor hum when it should, there is no service procedure available for these sealed units.
Feb 22, 2008 | Kenmore 54501 Dehumidifier
Whirlpool AD50USS Dehumidifier Logo
480 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Daniel Phillips
Daniel Phillips
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
