Question about Brother MFC 8840D All-In-One Laser Printer
Machine error 6a Brother 8840D
Was making loud grinding noise.
I just replaced new drum. I checked for broken brown gear , but it is fine.
What else could it be?
Thanks
Paul
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
Posted on Jun 10, 2010
Machine error 6a
Posted on Apr 26, 2010
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
Hinge and paperfeed
You need a new hinge, #LP2403001, and the grinding is because the fuser has a broken gear.
Jul 25, 2009 | Brother MFC-8840D All-In-One Laser Printer
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Gringing noise and says to replace drum. Replaced drum and still grinds and says drum needs replaced
look at front of machine where your received faxes come out. you will see a couple of rollers there. unplug fax, and while watching the rollers, plug in and see if they turn when machine starts rotating. if they don't, you have a broken heat roller gear. another thing can cause this is a bound up toner cartridge. try another if rollers are turning. last but not least, your old drum possibly damaged your drum drive gears.
good luck,
razors
Feb 19, 2009 | Brother IntelliFAX 2800 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
Recieving fax error
It could be a bad drum unit. If the drum doesnt turn smoothly it will make a clicking or grinding noise since it is gear driven. Take out the drum and turn the gear with your thumb. turm towards you. If difficult Thats it. It also could be a fuser gear. good luck Lawrence
Apr 22, 2008 | Brother IntelliFax-2820 Laser Fax
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Beating Noise emanating from the Printer Brother MFC8840D
Worked on one of these today that had a broken gear on the fuser. It takes about 8 screws to pull out the fuser fom the back of the machine, but the gear is visible with the fuser removed. If it is broken or teeth missing, I found a new one at precision roller for $129.00. They offer the gear only but I didn't want to take the time to replace it and other parts were worn anyway.
Aug 30, 2007 | Brother MFC-8840D All-In-One Laser Printer
Brother MFC 8840D All-In-One Laser Printer Logo
1,217 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
