Question about Seagate 250GB 7200RPM ATA DVR Drive: 250GB-ATA-DB35 Series 7200.3 hard drives offer the industry s m... 250 GB EIDE
Which Portable hard drive can be used with both a Windows PC and an Apple iMac please
  • 6,831 Answers
Hello
Well, you can basically buy any external drive and it will work on both operating systems if you format it to a FAT32 format.
If you buy a new drive, you first need to delete the partition on the new drive using Fat32 formatter, and then format it in Fat32 file system.
Here is a link to where you can download the software for free, and get instructions on how to do this.
http://tokiwa.qee.jp/EN/Fat32Formatter/
Hope this can help.
Kind regards
Andrea
Posted on Nov 16, 2009
I have an external WD My Passport hard drive but Pages says it cannot create a file when I try to save a document on the external hard drive. Is it because the file format is not compatible with Imac? Can...
Apple Pages has a few bugs like this. There is a work around.
  1. Save to Desktop or Documents folder on the System Drive
  2. In Finder, move the file to your external drive.
  3. Now when you open the file from your external any saves will continue to go to your external drive.
It's a bit of a pain but works for now.
All the best
Mar 29, 2015 | Apple iMac Desktop
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
Iomega 1TB HD Works on iMac but not on Windows Laptop?
as the mac has a diffreent format to a pc you cannot connect up the drive to a pc because it simply wont recodnise it. the best way is to network the 2 computers together then alow file sharing on the mac and searcc with windows through the network to find the drive. then copy them across the network to your pc. this will then reformat the files to PC files at they hit your PC
May 17, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Apple imac HDD install
Pretty sure any size, but they use 3.5" SATA drives, not 2.5 laptop drives. iMacs only use desktop drives so get as big as you want, or can afford with a big cache. The 17 imacs are hard to get into so search the internet on how to get in and replace it and to put the heat shield back in right. Be careful not to break the clips.
Sep 26, 2009 | Apple iMac 17" MA199LLA Desktop
I just purchased a WD400GB portable hard drive. I
Hi. Yes it should wok on your MAC
by doing this >>> http://tinyurl.com/5bnyj9
Hope this helps but if not reost and ill try to help you further ok ;-)
all the best
Mark
Aug 24, 2009 | Western Digital WD Passport 250GB Portable...
Imac G5 harddrive replacement
i think you r right,
please get the same checked by an Apple technician
Jun 17, 2008 | Apple iMac G5 Desktop
Playing PS2 on apple iMac
if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
you could buy an external CD/DVD drive and then use smaller discs with the iMac.
Jun 10, 2008 | Apple iMac G5 Desktop
Seagate 250GB 7200RPM ATA DVR Drive: 250GB-ATA-DB35 Series 7200.3 hard drives offer the industry s m... 250 GB EIDE Logo
48 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
