Question about Air Tools & Compressors
My power painter makes a buzzing noise but no paint comes out. Cleaned it out, tried to run water through it. Is something broken?
  • 10,865 Answers
Hi. I can assist you. Power sprayers are difficult to clean. They also tend to rust on the inside when put away wet. That said, completely disassemble your power painter and inspect every part. Just a small amount of dry paint in some of the tiny openings will cause the symptoms you are having. Once you are sure the parts are all clean, reassemble the gun and once again try running water through it. If you still don't get a spray, turn the knob that increases the pressure and the level of the buzzing noise.
One last thought, once your gun sprays water you will be able to spray somewhat thicker liquids but if the liquid is too thick it will not go through so do not hesitate to thin it.
Posted on Nov 17, 2009
I want to repaint the exterior to make it look nicer and treat the rust what paint would you recommend please?
sand back and treat the rust with a phosphoric acid rust converter,then prime and paint as per usual,you question does'nt state where you are and local regulations usually say what sorts of paints you can or can't use
Mar 15, 2015 | Cars & Trucks
How can I fix a electrical spray gun that does not spray but makes noise like its going to spray.
R D, I think the spray nozzle is blocked with previous paint job. I would try soaking it in paint solvent for a few hours to see if it helps. Use the cleaning brush to clean as much as you can all the channels where you see paint. good luck.
May 20, 2014 | Wagner Spray Tech Model 242 Electric...
It is making buzzing noise inside
There are 2 possible cause of that noise 1 is coming from your fan motor and the 2 is the compressor stand is broken. Or water that never comes out on the pan of the air condition try to drain it first before proceeding the 1 and 2 tips.
Sep 11, 2011 | LG Goldstar GWHD5000 wall/window Air...
Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
Wagner power painter 325 not spraying right-comes out in clumps and spatters even when trying with water
You should be able to adjust the spray pattern to clear this up. You may also give it a good cleaning with mineral spirits as well as making sure that the paint is thinned enough
Mar 12, 2010 | Wagner Power Products 0154842 Medium Spray...
Whirlpool cabrio-buzzing noise when water runs
i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Status is 'printing' but its not printing at all
have you tried installing the original drivers that come from vendor in the box? this problem usually occurs when you have some driver issues.
Sep 18, 2009 | HP DeskJet 5150 InkJet Printer
Air Tools & Compressors Logo
621 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
