Question about HP LaserJet 4600 Printer
It leaks. It's all over the inside of machine. We don't use this printer a lot because we do design on-line; so it's not from overuse or worn out parts. It just leaks and then causes the printer to stop running because it's out of magenta toner!
I have had problems with a number of brand new genuine HP toner cartridges leaking on this printer. Strangely, I have had almost no problems with non-OEM cartridges from Cartridge World.
I can’t explain this...and wouldn’t have believed this if I hadn’t experienced it myself.
Try removing all toner cartridges, and carefully cleaning out the printer with canned air. Then replace the leaky toner cartridges with Cartridge World cartridges. This has been my recipe for success with the HP Laserjet 4600.
Posted on Dec 14, 2009
PT cruiser oil spraying in cylinders why
Please share how you are getting inside the cylinders to see oil spraying inside whilst the motor is running?
Give us a whole lot more information, perhaps we can help.
God bless your efforts.
Jan 23, 2017 | Chrysler PT Cruiser Cars & Trucks
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
My whirlpool washer is leaking from the front center. Happens during spin cycle I think.
Hello.
If your washing machine is leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Bellow are Instructions on how to solve the problem of leaking washing machine
    • 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
    • 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
    • 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
    • 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
    • 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
    • 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks.
Sep 03, 2011 | Whirlpool Washing Machines
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
I have a designer 1 and when i put the Walking Foot (whatever husquvarna call it) onto the machine it stitches extremely small stitches, how the hell do i get it to stitch at a descent length?????? HELP...
Make sure the u-shaped arm that is on the walking foot is "over" the needle screw i.e. the needle screw should be inside the u shape. The feed dogs need to be up also. Use the SET menu to set the machine for the correct fabric and function.
Is the walking foot new? I had one that I used a lot and it went nutty and had to be replaced. I pulled it apart and could not find anything out of place/worn out/broken but it just did not do the job any more. The new one works great.
Nov 06, 2010 | Husqvarna Designer I
LG leaking from bottom, Not the filter clean-out.
Not necessary to blame LG, ALL of these front loaders are garbage. They were designed poorly and released too soon just to have a new gimmick.
Jan 16, 2010 | LG WM2688HWM TROMM SteamWasher
My washer keeps leaking grease onto my clothes!
the problem that you have is the bearings have badly worn,a lot of companys will just replace the entire drum rather than mess about with the bearings as this does not always solve the problem.sorry to give this bad news.
Jul 15, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Oil leak in washing machine
Sounds like the transmission is leaking. These transmission don't need to be full of oil to function. But, if it's leaking a lot, like tablespoons, it should be checked. It's not the end of the line. Just may need a service call if it's a plentiful leak.
May 05, 2009 | Washing Machines
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
HP LaserJet 4600 Printer Logo
346 people viewed this question
Seeker5211
Seeker5211
