Question about Toshiba 50H13 50" Rear Projection Television
"No Disponible" Message on screen..
Toshiba 50H13 Chassis TAC0360 Manu. Oct 2003.
The TV powers on. I press ANY button on the front panel and the screen displays a message: "No Disponible". Is this Spanish? Disponible means Available in English. So it says No Available? I have tried changing the channel or the inputs or the using the menu.. still sae message. I am stuck. Please help.
  • dvsax Jan 10, 2008
    Never mind it's the INPUT LOCK option in the menu. I found it on a remote, the code was 0000. THnx
  • rickoy palmer Mar 02, 2008
    I am having the same problem i have all my inputs on lock and and i mad a mistake and turn on my front panel lock on my toshiba. i have the code to unlock it but it seem like the enter button on my remote does not orn on the tv i usually use the manue button on the tv as enter but now the pannel is lock and i need to hit enter when i type the code in. plz help me
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
SOURCE: Toshiba 50HP66--can't change channels anymore
I had this problem. Unplug it while it is powered on. Worked for me.
Posted on Nov 03, 2008
  • 7 Answers
SOURCE: Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Posted on Nov 14, 2008
SOURCE: Toshiba Satellite A60
This problem occurs when the internal battery dies and you loose data for the internal clock and possibly the bios. Refer to this link: http://209.167.114.38/support/Download/files_downloads/PSA60C/SA60EXUM.PDF and go to page 125 in the manual.
Posted on Nov 20, 2008
SOURCE: Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Posted on Dec 19, 2008
How can I restore the tv signal on my Toshiba 32DL934?
    • 1 Locate the "Power" button on the front of the TV.
    • 2 Press and hold the "Power" button on the front of the TV.
    • 3 Hold down the button for longer than five seconds, then release.
May 29, 2015 | Toshiba Televison & Video
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
How do i get service mode on Toshiba TV22DV615DB
1. Turn the TV on.
2. Press the {MUTE} button three times on the remote.
3. Press the {MUTE} button again on the remote and hold.
4. Then press the {MENU} button on the TV's front panel.
5. Release both buttons
6. There should be a letter "S" on the upper right of the screen.
7. Press the {MENU} button on the TV's front panel again.
8. You are now in Service Menu.
9. Use the {CH+} or {CH-} buttons to select the item.
10. Use the {VOL+} and {VOL -} buttons to adjust the value.
11. Turn the set off to exit the Service Menu.
Oct 24, 2012 | Toshiba 22DV615DB 22 INCH LCD TV COMBI IN...
Service manu of svl color tv
volume level at 0(zero).Then press v- at front panel & display on remote at a time , 'S' appear on screen. Then repeat 'D' appear on screen.Then press 'menu' on remote service menu will appear.
Apr 06, 2012 | Televison & Video
Bottom portion of screen is cut off. How do I reset the tv?
Hello
To reset your Sony TV, you have to enter its service menu options. It is very dangerous to enter into the sevice manu of any TVs, without proper knoledge. Factory reset option is described in the service manual of your TV. I'll give you the procedure, but be caucious, not to change any value of other paramters, some times the set will turn irreparable. Do only the things I describe here. Actually, this should be done by any experienced service technician. So BEWARE.
To get ito its service Menu
[1] Put the TV in standby mode. (Power off).
[2] Press the following buttons on the Remote Commander within a second:
DISPLAY /Channel 5/ Volume +/ POWER On.
The service menu displays
[3] Use the [DOWN] button to view the next category listing the white balance
adjustment items
[4] Continue pressing the [DOWN] button until the next category list displays
[5] Press the button to select TEST RESET options
May 15, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
The brand name Samsung is in the middle of the screen. I wish to remove it and with no manual I do not know what to do. Also there are other messages fliping on and off the screen too.
Method 1
  1. Press the Volume + button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
  2. With the volume bar displayed on the screen immediately press and hold the MENU button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the MENU button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 2
Method 3
  1. Change your TV to the "TV" source. The TV source is the coax (RF) source. It does not matter if you do not have anything connected to this source.
  2. Press the MENU button.
  3. Use the ??² or ??¼ button to select the "Setup" portion of the menu, and then press the ENTER button.
    Note: On many TVs the menu sections name is displayed on the left side of the menu and sideways.
  1. The "Plug & Play" option should be highlighted if it is not use the ??² or ??¼ arrow to select "Plug & Play" option, and then press ENTER.
  2. Note: If the "Plug & Play" option is grayed out and can't be selected this means that you are not on the TV (Coax (RF)) source. Please return to step 1.
  1. Follow the on screen instructions. When the options comes up select "Home" instead of "Shop".
  2. Finish going through the plug and play option and your TV will no longer be in Shop Mode or Store Demo.
Feb 01, 2011 | Samsung TXD1972 19" TV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Toshiba 50H13 50" Rear Projection Television Logo
139 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
