Question about HP LaserJet P4014n Printer
Load Tray one Bond letter. I want it to get the paper from tray 2 without having to override it each time.
2 Suggested Answers
  • 217 Answers
SOURCE: Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Posted on Jul 29, 2010
How to make default tray 2 in HP Laserjet p3005n printer
HP printers will default to the highest numbered tray that contains plain letter paper. So on a standard 3005 Tray 2 is the default unless you have the paper type set for something other than plain letter. If you have an additional tray, then Tray 3 would become the default tray if it is set to plain paper. In this case, you would set tray 3 to either bond or letterhead so that the printer would only grab from that tray if you request either tray 3 be used or create a job that calls for that type of paper.
If this does not sort it out, post back again with a complete description of the printer including number of trays, what is loaded in the trays and how they are set for both paper size and paper type. This information can be found by printing a configuration page. This is done by pressing the arrow key on the control panel until display reads information, press checkmark (green button) then use down arrow until Configuration page is displayed and then press checkmark again. Page will print that shows all the settings for the printer.
May 08, 2011 | HP LaserJet P3005n Printer
I have HP laser jet 4350dtn heavy duty printer. It is attached with thye network point. And the configuration is done on the server. Then for the client machines I install via from the server since it is...
1 of 2 things. Either the paper type and size is not set right in the printer menu for tray 2. or the physical setting in the tray are not exactly on letter. The printer is looking for letter paper and does not see it in tray 2. If you load tray 1 with paper and press the green button my guess is it will use that paer and tray. First chack to make sure the setting in the tray are exactly on letter, it uses that and little fingers on the left side to tell the printer there is letter paper in the tray.
Jan 13, 2011 | HP LaserJet 4350 Printer
Jul 28, 2010 | HP LaserJet 4050 Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Iam facing in hp 4050 printer,when i have giving command from tray 2,printer is giving error on display 41.3 unexpected paper size but from tray 1 is working ok.i have done already in paper handling menu...
swap trays and test - if OK then your tray is set up wrong. remove paper and check that it is set for letter. also check the small switch (if there is one) on the Right hand side of the tray that maybe set to customer - change to standard. compare trays so they look the same - and check the settings in the menu for letter / plain on both trays
Jun 04, 2009 | HP LaserJet 2840 Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
Max Paper Weight
Here ya go...
Tray 1: (standard) 16 lb. Bond – 80 lb. Cover (60 – 220 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, business cards, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards, Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, A5, A6, B5 JIS, B5 ISO, 3 5 in. Index Cards, custom sizes; Envelopes: #10 Commercial, DL, C5, #5 , #6 , Monarch, Booklet, Lee (A7), Choukei 3 Gou, Choukei 4 Gou, custom.
Tray 2: 525-sheet tray (standard) 16 lb. Bond – 28 lb. Cover (60 –122 gsm), coated, Phaser High Resolution Photo Paper, labels, envelopes, Phaser Professional Solid Ink Transparencies, Phaser Weatherproof Paper, Phaser Postcards,Phaser Trifold Brochures. Media sizes: A/Letter, Legal, Executive, Statement, US Folio, A4, B5 JIS, B5 ISO; Envelopes: #10 Commercial, DL, and C5.
Tray 3: 525-sheet Feeder (standard on DX) Same media weights and sizes as Tray 2.
Tray 4: 525-sheet Feeder (optional) Same media weights and sizes as Tray 2.
Nov 12, 2007 | Xerox Phaser 8400 Laser Printer
HP LaserJet P4014n Printer Logo
981 people viewed this question
Seeker5211
Seeker5211
