Question about Dell Latitude 110L Notebook
My computer screen completely froze for about 1/2 hour. After powering down, I could not get my laptop to restart. The power indicator lights come up and about three seconds later they go off. Laptop will not turn on?
  • 94 Answers
If you can clean the hard disc on your own do that if not i suggest you meet a technician or do key check to make sure your key settings are ok being YES or ON.
Posted on Nov 16, 2009
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
Laptop froze now wont restart
remove the laptop battery and turn it on now check the led indications
May 09, 2012 | Toshiba Satellite Computers & Internet
Computer froze and will not restart
You need to reset the firmware.
Remove the battery, and boot up but holing the power button down until you hear a loud Beeeeeeeeep, and the lights start flashing. Let go, and wait.
Regards.
Jul 21, 2010 | Apple MacBook Pro Notebook
My laptop froze up:
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Mar 10, 2010 | HP Computers & Internet
Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Feb 15, 2009 | Computers & Internet
Dell laptop
Remove the CD Drive from the computer , disconnect the charger from the computer , flip the laptop and remove the battey, with the battery disconnected , push the power button for 10 secs to release the flea power , open the memory slot , remove both the memory sticks and then put back only one of the memory stick and then try restarting your computer. If it gives out the msg amount of memory changed , then Strike F1 to continue...
Apr 21, 2008 | Dell Latitude D600 Notebook
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Starting up
press the power button for some seconds
Jan 29, 2008 | Computers & Internet
Dell Latitude 110L Notebook Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
