Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
I just replaced a 4 wire 3 speed pull chain switch on my ceiling fan and now it still wont turm on. It is making a humming sound now. I was careful to match wiring???Please help
    President:
  • 2,702 Answers
It sounds like the new switch has a different pin out or you got it wired wrong? is the motor jamed up, will it turn by hand,,,the humming sound you here is curent running through the motor windings,, if it cant turn its going to get very hot,, it could burn the motor out,, have another look at the wiring
Posted on Nov 16, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
I have a 3 speed fan controlled by 3 speed wall switch; fan hums on low, louder hum on medium, and high position eliminates hum but speed reduced to low. Is it the fan or the wall switch?
Check the capacitor (black box with wires going to switch) and see if that's going bad. If it's not that, take the control out of the wall and just use the pull chain to see if it runs correctly. If it does, you need a new wall control. DO NOT USE A DIMMER SWITCH!
Aug 04, 2014 | Concord Fans PB-1032-ORB ARACRUZ Oil...
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
3 speed ceiling fan switch installation
Fan is wired wrong, but you need to test using multi-meter.
Buy cheap multimet from hardware, install battery, set to read ohms or the upside down horseshoe symbol
Copy following link for testing wires:
http://waterheatertimer.org/How-to-wire-3-speed-fan-switch.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2012 | Hunter (25417) Ceiling Fan
Old fan switch has 4 wires, new one has 3. A Ceiling fan light switch is for the fan, not the light, correct?
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202191016&langId=-1&catalogId=10053&PID=500871&cm_mmc=CJ-_-500871-_-10368321&cpncode=00-29062147-2&AID=10368321&cj=true&srccode=cii_9324560&locStoreNum=577
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
2) Ceiling fan pull chain switch is for the fan only.
Jul 18, 2011 | Westinghouse Electric Ceiling Fan 3-way...
How to attach an on/off chain to a ceiling light- the original broke off somewhere inside. The fan switch is intact. This is one unit.
You need the little coupler thing that connects to the ball that makes up the chain. If you dont have the coupler ... you could get one at your local Ace Hardware store ... or you could just purchase a similar switch which would have the coupler on the chain.
Jun 07, 2010 | Leviton 1689-050 Pull Chain Fixture Switch
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
692 people viewed this question
Top Westwind Dryers Experts
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
