Question about Kodak EasyShare DX4900 Zoom Digital Camera
The battery will not hold its charge after charging. A New battery has the same problem
  • 49 Answers
Sounds like charger or adapter is faulty does the light stop blinking?
Posted on Nov 16, 2009
Why does my 150 cc SUNL scooter not hold a charge? New battery is no different than original. It is a 2008 with 26 miles on it
Doesn´t matter the miles runned.
The battery is too old. chemicals inside are not capable to hold Current(Amperes).
Yo must change the Battery by a New one with the same parameters. (Volts,Amps, Size.)
2008 from now it´s too much time for a Battery, even unused.
Oct 21, 2014 | UPG 12V 12Ah SunL Tiger Scooter Battery -...
Battery won't hold a full charge
batteries don't have a life forever. And no one can predict the life time of a battery.
So many factors influence the lifetime. But if it is draining very fast, this mostly means it has reached the end of life. If the camera does not get excessive hot, it has nothing to do with the camera. It is just you need a new battery.
To keep a battery in shape for a longer time you should charge it also when the camera is not used. Like at least 4 times a year. Always charge the battery a day before you plan to use it. Don't over charge, like charging it every day. Don't leave it in the bright sun or on a hot place.
A new battery, should be charged and discharged a few times, before it gets a full charge.
The "New" battery you bought, could be in stock for a long time. Special when you could buy it very cheap.
Perhaps in a few days you say, he the battery works fine now. But if you did charge it 3 or more times and it still does not hold a charge. send the battery back (I hope you bought one with warranty)
Aug 14, 2014 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Motorola radius cp200 will not hold a charge
when charging a new battery for the FIRST time, most require a full 24 hours to be properly charged. Failing to do this will drastically diminish the life of the battery. If you did fully charge the battery the first time, another issue is recharging after EVERY use vs charging when completely drained. Battery will develop memory (although the manf. will say other wise). If you charge after every use and have only used a third of the charge, after a few time of doing this, you will notice that the battery will not last as long. Try one more battery in just one raido. Fully charge it the first time and only recharge when COMPLETLY drained. If the battery is still not holding a charge, it is most likly a short in the radio itself. Return it.
Jan 07, 2014 | Radio Communications
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
Will not hold a charge. model 7617x norelco
According to your problem, you have to change the battery with a new. After several times of charging and uses charging battery also get dry. Then the battery can't hold charge. Only you have to switch a new cell.
May 13, 2011 | Norelco Quadra 7617X Electric Shaver
Does not hold battery charge
Since you have a new phone and a new battery and is still doesn't work ... the first step should be to take it back to where you got it ... have then evaluate it for possible replacement.
May 16, 2010 | LG Shine KE970 Cellular Phone
Phone not holding charge with new battery
Have you try to use another charger to charge and it doesn't hold charge? if yes., no problem because it be that your charger is bad. But since it does not charge with another charger, it means the charging port is bad.
The problem with the phone is the charging port, the charging port of your phone is not charging the phone that is why it doesn't hold any charge,
All you need to do is to change the charging port of your phone and you will see that your phone will hold charge.
Take care.
Apr 28, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Battery New battery won't hold a charge on Acer 3100
New battery will typically take 12 hrs for first charge.
Mar 08, 2010 | Acer Aspire 3000 Notebook
IRiver H340 new battery won't hold a charge!!
It can be the charger that is actually causing your battery to not hold a charge. The closest thing to you would be www.iriverstore.com. connie
Jul 09, 2007 | iRiver H340 MP3 Player
Kodak EasyShare DX4900 Zoom Digital Camera Logo
49 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
