Question about RIM BlackBerry Curve 8520 Smartphone
My blackberry seems to have a problem when i try to scroll down it immediately scrolls back up, it like it moves om its own, and in some case it moves with out me even touching the trackpad. can someoe tell me wats goin on.
No 3G network mode on my blackberry 9700 bold please help me
Look for the manage connections icon on your phone (looks like a small little antenna tower) and click on it - scroll down to Network and connections and click - click on Mobile network - scroll down to nework mode - select 3G & 2G. Some handsets have 3G and 2G separately. Select the 3G in your case.
Enjoy:)
Mar 13, 2015 | Blackberry Cell Phones
I can't move up and down the scroll of my blackberry phone.what should i do?
is scroll dirty, must clean
open cassing ond claning with tissue
Jan 22, 2011 | RIM BlackBerry Pearl 8100
My blackberry scroll bar is malfunctioning - sometimes I cannot get it to scroll up and down only scrolls side to side.
You can try removing the scroll ball and cleaning it, that could be the reason why it wont scroll up and down.
www.usedcellphoneshop.com
Jun 07, 2010 | RIM BlackBerry Pearl 8100
I need to copy my contact in my memory card to my new blackberry phone
insert your memory card and go to your scroll your menu to file then you find Phone memory and memory card then click on memory card on top of a conatct you have there press your option and scroll down where you will found mark, mark all then click on mark all and then it will ask copy or move then you click either one of the two then it goes immediately ok.
rate this solution pls
May 05, 2010 | AT&T BlackBerry Curve 8310 Cell Phone -...
The ball won't scroll down
Have you removed the ball at any time? If it is put back in wrong, it could cause this. If not, the ball assembly itself might be bad. You can find them fairly cheap on eBay.
May 30, 2009 | RIM BlackBerry 8800
Blackberry curve scroll button sticking
I had a similar problem, and the only solution is to change the trackball which cost between $5 & $10 dollars on e-bay. An easy and cheap fix, it comes with the tool to replace the assembly. A kid can do the job
May 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
CUrve 8330 having trackball error
Hi
It seems that there might be something blocking it, like dust, press the trackball down and then try to scroll quickly towards the bottom, try it a couple of times, it should fix your problem
David
CellUnlock.net
Feb 26, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
Trackball moves but cursor will only move down and left to right not up
try takign out the batery if that doesnt work click it a bunch of times to losen it up
Mar 27, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8520 Smartphone Logo
208 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
