Question about Saeco Starbucks Sirena Espresso Machine
Need portafilter plastic support peg
I need to order the Sirena portafilter plastic support peg, not the entire portafilter. Is this possible and where can I order it? I simply lost it since its such a small part. Can I order more than 1 in case I lose one in the future?
  • 3 Answers
This merchant carries Saeco/Gaggia parts. You may have to get the disc and peg as a set. Part number/description is: "GG1038/01/A Crema disc for portafilter. Use with 2-cup basket"
Merchant site is here:
http://www.saecoparts.com/StarbucksSirenaespresso.html
The item is on the 3d row, 4th column
Posted on Nov 26, 2009
Try http://www.saecooutlet.com/supportpeg.aspx
Posted on Jul 18, 2010
Will a Starbucks sirena portafilter fit on a Starbucks barista?
The Sirena portafilter is 58mm and the Barista portafilter is smaller at 53mm so the two are not interchangeable.
58mm is a fairly common size in portafilters however, so if you are looking for something different for your Sirena, there are options. Also the Sirena has a rubber disc and peg to function as a self-tamper, those can be removed so you can tamp your own grind and adjust it to your liking.
Jan 26, 2015 | Saeco Starbucks Sirena Espresso Machine
I can't get the water to come through the coffee holder. It builds up pressure but won't shoot the coffee out. The water comes out if I take the holder off , but not when it is in place. Do I need a new...
Remove the brew head. Pry out the metal coffee filter, then pry out the rubber gasket. There is a small black plastic insert that is likely gunked up with coffee buildup. Clean the parts well, reassemble, and then try again.
If you are a good "tamper", you can leave out the rubber gasket and plastic insert entirely, and just go with the the filter. It takes a bit of practice, but you will get equally good crema if you match the grind to your tamp pressure.
Jun 21, 2010 | Saeco Starbucks Sirena Espresso Machine
Starbucks sirena won't heat up; blue light flashing-brand new
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Hoover stean vac dual with 5 brushes
I think this is the same unit I have, I might have a couple of solutions. No, there is not a belt that turns the brushes and there is not a fuse.
First of all, make sure the brushes have been clicked into the machine properly. The entire plastic housing unit for the brushes can be removed by pulling on the casing gently. It should pop out. Make sure the pegs and clips line up with the holes in the machine when reattaching the brushes. You should hear it click when they are on properly.
If the brushes are attached properly and they still won't spin here is another possible solution. This happened to mine.
The plastic pegs on the housing unit for the brushes might have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you.
Aug 30, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Water sprays out between portafilter and brewhead.
I had the same problem when I started using the Sirena. When I put the portafilter on I was lining it up with the arrow. I found that if I tighten the portafilter on all the way to the right (past the arrow) it works perfect, no water spraying.
Jul 03, 2009 | Saeco Starbucks Sirena Espresso Machine
Double shot won't work, single does
Try using without the portafilter, if it works then the problem is in the grind or the pressure used to tamp the coffee.
May 19, 2009 | Saeco Starbucks Sirena Espresso Machine
Replacing orange gasket in top or portafilter
here is a picf920683.png of the portafilter for the saeco
May 09, 2009 | Saeco VIA Venezia
Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
781 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
