Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman riding lawn mower tries to start and just putters then it backfires and shuts down.
    President:
  • 2,702 Answers
It sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Posted on Nov 16, 2009
Craftsman lawn tractor
Backfires are caused by unburned fuel, after you shut off the mower, and you try to restart it, if you have any leaks, it will push any unburnt fuel towards the muffler, and that will ignite once it gets in a hot muffler. First try starting it at 1/4 to 1/2 throttle. I also suggest you try shutting down the motor at 1/4 to 1/2 throttle.
What this problem usually means is you need to rebuild your carburetor, with this poor quality ethanol fuel they force us to use these days, it will eat up your gaskets and rubber seals inside your carb.
What I found that helped me with my mower, was using non-ethanol gas. Its hard to find and is usually expensive, but that solved most of the problems I was having with my 10 year old craftsman mower, which has the 17.5 kohler motor.
Apr 27, 2014 | Craftsman Garden
Craftsman lawn tractor backfiring
clean the jets inside the carb
Aug 06, 2012 | Craftsman Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Lawn mower not running
sounds more like the carb sucked up something if u take it off and tear it down let soak in solvent than blow air thru body to dry and clear passages dont mess with adj
Sep 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
754 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
