Question about Kodak EASYSHARE 5100 All-In-One Printer
New ink not working three different times buying it and taking back ink very light or none at all no red it shows up yellow?
  • Kodak Master
  • 11,800 Answers
Clogged heads due to bad or dried ink. Go into the Maintenance section of the menu and do a Deep Cleaning.
Posted on Nov 16, 2009
  • 49 Answers
Pritn head probobly clogged search online for cleaning info.
at KODAK
  • 262 Answers
Have you done the cleaning the printhead? if not please run your clean printhead, if your using 5100 printer you can only do clean printhead by launching your home center, just click the help icon(?) under that click maintenance for you to able to see clean printhead
Now if you already done with this torubleshooting and still you haved incomplete color or incorrect colors printouts it means you printhead is defective., YOu need to call kodak tech support for printhead replacement i think its free of charged 1 800 421 6699 ext 05 toll free
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Yellow ink showed empty. Replaced cartridge with three separate cartridges from three separate stores. It still shows empty and won't print.
I can imagine the frustration but I want you to try this procedure:-
Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with yellow ink it means you still have a good amount of yellow ink in it and the nuzzle is not blocked. If not blotted or scantily blotted, it means yellow ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink will NOT work! NEW cartridge!!!
Your print head is already clog, if you can find chemical solution in your area,you can try to soak it without removing the print-head, on its parking put some solution then let it be there for 24 hrs then try printing,do this for three days if nothing happens,buy a new printer, because buying a print head is not practical, it almost cost the same as a new one.
Sep 18, 2009 | Brother MFC 420CN All-In-One InkJet...
Black not printing / HP OfficeJet Pro L7590
Firstoff,
Good on you for trying all of the above, if your printer has a print head problem you can find out easily by going into your printer toolbox.
Double click the HP Digital Imaging Monitor on the taskbar to the left of the clock.
when it opens click Settings=>Printer Settings=>Printer Toolbox
Ink levels will be displayed there, If the Black ink is showing empty the sensor for that cartridge must be dead(three strikes), Call HP and request a warranty replacement, or, take it back to staples as they generally handle 1 year in the store.
If the black in is showing here then the sensor is good, click the Information tab at the top of this window, then click Printhead Health. If the Black/Yellow is yellow or red Call HP and they should issue you a new one under warranty. If it is green this is not the problem.
Continue by closing that window, then Clicking Settings=>Printer Settings=>Printer Settings
Click on the Colour tab then switch the printer to greyscale and try printing again.
If this doesn't clear the head it may simply be caked or have an airlock.
To ensure it isn't caked simply soak the head in rubbing alcohol 2-3mm deep on the head for an hour or so, then replace it and try again.
Unfortunately if none of these work you may be stuck dealing with HP for a warranty exchange, www.hp.com click support then click chat with an online support technician.
or talk to your staples rep about having it replaced through the instore warranty if you have instore coverage.
Hope this helps FixYa,
Chris
May 19, 2009 | Office Equipment & Supplies
HP LaserJet 3600dn Printer Problem The printer is new but wil not function.
In menus, diagnostic menu, "show event log". What error codes are listed?
Apr 12, 2008 | HP LaserJet 3600dn Printer
Our tv has two inputs not three. The player has three outputs. The tv has one for audio and one for video. We are unable to get the philips to function under these circumstances. ps we have three different...
ok i am guessing that you are referring to RCA type hookup, if so there are 2 different types - yellow/white/red and red/green/blue no your TV probably has 1 yellow and 1 red or white if this is the case then make sure that you match up the yellow with yellow and then for the red and white these are for sound and you can buy a conversion cable at wal-mart for under $5 just make shure that it is 2 female RCA to 1 male RCA then plug both the red and white into the female sides and the 1 male into the one on the TV - now the channel that this input will show up as will most likely be AV1 or AV2 not a normal channel like the VCR did with channel 3
if you tell me the brand and model # on TV i will look it up for you and give you a more detailed description
Apr 04, 2008 | Televison & Video
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
142 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
