Question about Acer Aspire One PC Notebook
Restored aspire one to factory settings cant get online now
  • drnow May 11, 2010
    re setup your internet connections. you have left out way to many variables for much help. like o/s type of internet connection does your modem have a WEP code etc.
zohail
  • 1223 Answers
SOURCE: restore factory settings
there are 2 ways for doing this
1) Fast and easy without backup disk just do this
Acer: When you turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
2) If the method above doesnt work u can do it thru backup disk u have got when u purchased ur laptop u shud have made it thru Erecovery software.
Pls rate me FIXYA for help !
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: acer aspire 6920 back to factory settings
on the first screen that says something like "F2 to enter BIOS" and "F12 to change boot order", hit F10 (maybe Alt+F10 or Ctrl+F10, not sure) and it should pull up the recovery console.. just read carefully, the only option there might be reformatting C:
Posted on Jun 22, 2009
  • 52 Answers
SOURCE: how to restore my acer aspire 5001 to factory
Hi I contacted Acer about this myself and this is what they wrote back.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 52 Answers
SOURCE: restore back to factory settings
From Acer direct
If you see this:
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
How to unlock acer mini laptop
Instructions to factory restore!
Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Dec 27, 2014 | Acer Aspire One AOA150-1949 Laptop
Restore to factory settings
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to "Start" > "Restart" to reboot your netbook.
Hold down "Alt" and "F10" when you see the Acer logo on the screen.
The recovery menu will load.
Hit "Enter" and then "Next" to see your recovery options.
Choose "Factory Restore" to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
Jun 13, 2013 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire one d257-1417 trys 2 setup service but cant sumthing happen 2 microsoftwindows how can i recover without a cd
I'm not sure what you are referring to ?
If you do a factory restore and its a hardware issue the problem will still remain
You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive.
Feb 02, 2013 | Acer Aspire One PC Notebook
I dont know how to restore my acer with linux back to factory settings
The Acer Aspire One is a netbook, not a laptop. A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop. It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature. You can reset the Acer Aspire One to factory settings just using your keyboard. Only restore your netbook to factory settings if you cannot fix the problem any other way.
Jan 20, 2013 | Acer Aspire One Netbook 8.9" Notebook
I DONT KNOW HOW TO RESTORE MY ACER BACK TO FACTORY SETTINGS
Jan 20, 2013 | Acer Aspire One PC Notebook
How do you restore to factory settings on a acer aspire 3100 without a disc?
you could use the program System Restore.
It restores the computer to a certain time in the past kind of like time machine. And it is pre-installed on a windows computer.
Tutorials are available online so just google it.
Jul 13, 2011 | Acer Aspire 3100-1458 Notebook
Virus and cant restore factory settings
you should be able to hit the ALT+F10 button when u first boot to do a boot up factory restore
May 18, 2009 | Acer Aspire 5315 Notebook
WILL not resetting to factory settings
You will need to burn a Recovery CD / DVD set from the icon located on the desktop/ In your Acer Home Start utility (The window loading at startup) or from the Start Menu.
Using this disk you will be able to do a System Restore back to original factory setup.
Apr 14, 2009 | Acer Aspire T180 PC Desktop
Acer Aspire One  PC Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
