Question about Makita 18V LXT Circular Saw
I have the same problem the charger won't charge and states it's broken. on 2 of my 6 batterys when will the next go?
    President:
  • 2,702 Answers
The battery pack has a number of small batterys in it any one of them can go down on you and then the hole pack go's dead and refuses to charge, if you can get the battery pack apart you could fix one pack by taking a good battery from one pack and replacing the dud one in another pack,the real secret is dont knock the batterys right out, recharge them before they go completle flat,,,and dont ever leave them flat or they will go into whats called a "supper discharged state" if they do there never going to recharge
Posted on Nov 16, 2009
Testimonial: "thanks will give it a go"
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Black out after churger was unplugged
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 23, 2012 | Acer Aspire 5742 Notebook
Dewalt lithium battery won't charge
Your problem states you have a Makita tool and your question is about a Dewalt lithium battery. In either case if the battery won't take a charge or if the charger is showing the battery is defective the only fix is to replace the battery. Some causes for defective batteries or batteries that won't take a charge are bad cells in the battery, bad or shorted IC board in hte battery, broken or burnt connections between the many cells or between the cells and IC board or even bad or old cells that will no longer charge up. The time and effort needed to find out what the problem is then finding another battery to scavenge parts from (individual battery parts are not available) is never worth the cost of just buying another battery and going back to work with the tool(s).
Jun 27, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Works when connected to charger but no power from battery changed battery still the same
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
Gateway laptop Model No. NEW95 won't charge
If the main battery is not charging properly and you state the charger and battery are fine, then there is only one possibility, the charge circuits on the motherboard are defective, this is a very rare situation and I have seen it once in all the years of service, make sure the battery is not the problem because in most cases it is.
Mar 14, 2012 | Gateway Computers & Internet
My 2005 durango want cran over
What happens when you attempt to start the engine? If nothing happens when you turn the key,you need to check the battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested. If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
Jun 25, 2011 | 2005 Dodge Durango
Phone wot charge
I reccomend you take out the battery, and put it back in after 2 minutes. Next, if you are using a car charger, use the home charger instead. If you are using the home charger, use the car charger instead. The charger may be broken.
Nov 17, 2008 | Sony Ericsson K850i Mobile Phone
Makita 18V LXT Circular Saw  Logo
82 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
