Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble shooting light flashes three times.What part do you think is failing?
3 flashes is the combustion pressure switch . Mounted on the front mid high. Two silicone hoses run to it along with blue two wires. By now you have probaly got this fixed though.
Posted on Dec 28, 2009
    Problem Solver:
  • 4 Answers
If you haven't learned yet, there is probably a diagnostic cheat sheet stuck to the blower door, it should tell you what three flashes means.....If it is no flame/failed ignightion, your most likely suspect will be a carbide ignightor (you'll have to test for 120 volts with a multi-meter at the ignightor during the ignightion cycle). If three blinks calls for a pressure switch issue then you will probably want to make sure your drain lines are all clear to the flue system (90% furnaces are condensating furnaces as the water must drain out of the flue, inducer housing and combustion chamber, otherwise it will not draft properly giving you a "combustion pressure switch" failure)
Posted on Dec 29, 2009
  • 767 Answers
Doesn't sound like the furnace is lighting 3 flashes is no flame or ignition fail.
Posted on Dec 12, 2009
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Have an LP gas water heater with White Rogers control that cycles on and off 3 times before remaining on. Water heater is 5 years old with forced exhaust. Heats water fine once it remains on. Do you...
From what you say, I would CLEAN the thermocoupler with either steel wool or a green scouring pad (dry) and then wipe off the residue with a clean cloth. If you still have trouble then it could be a gas valve that is sticking.
Jul 01, 2011 | White Rodgers Water Heaters
I have a duraheat 125,000 btu auto start (salamandar) with thermostat that was used once time last spring. it won't start and my husband tossed the box and yes..insructions in the fall. starting...it...
Here is a link to the Owners Manual for your Dura Heat Model DFA-125 forced air kerosene heater.
In addition to how to properly operate it and perform routine maintenance, it has a trouble shooting guide, which should be of great assistance.
You can download and print this manual for future reference.
http://www.worldmkting.com/documents/DFA4560125_EN_SP_FR.PDF
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
I have a Dayton 3E366B hanging my garage, and it starts up -lights the burners - the fan kicks on, and then it shuts off... This cycle goes on and it does not run for long times to really get the heat up....
No I do not believe it is your thermocouple, as that only detects heat from the pilot light and permits the gas valve to open and have main flame ignition. I would be looking at thermostat placement, and safety limits built in to the heater. Making sure that the thermostat is not getting a straight on blast of hot air from the heater is my first guess. Try jumping out the thermostat by first removing the thermostat from it's housing and placing a jumper between the red and white wires as they are usually the control for heat. If your heater stays running it is the thermostat. If not you now have to trouble shoot all safety limits one at a time with a volt ohm meter and run continuity tests the limits should read closed except for the fan high limit it should read open until the temperature of the heat exchanger reaches it's set temperature. Remember to power down your unit when trouble shooting please.
Jan 11, 2011 | Dayton Heating & Cooling
Colman fernace blinking code 9 what is this
there should be a trouble code index on the panel that shows the wireing diagram good luck
Oct 03, 2009 | Coleman Propane Forced Air Heater...
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Air bag sensor keeps flashing
If a concern is detected, the air bag control module will communicate by flashing the warning indicator. A diagnostic trouble code (DTC) is logged by the air bag control module in a nonvolatile memory. For additional information, refer to Diagnosis and Testing in this section.
Lamp Fault Codes (LFC)
Item Part Number Description 1 One flash cycle: Driver air bag trouble code 2 Two flash cycle: Passenger air bag trouble code 3 Three flash cycle: Trouble code common to both driver and passenger air bag circuit 4 Four flash cycle: Safety belt pretensioner trouble code common to both driver and passenger pretensioner circuits 5 Five flash cycle: Driver side air bag trouble code 6 Six flash cycle: Passenger side air bag trouble code 7 Not used 8 Not used
Apr 10, 2009 | 2001 Ford Focus
Colman Furnace keeps kicking on & off
Denise, my heater not a coleman (a monitor heater (oil) kept turning off when the temp got really cold. I would advise you to ask if you can do this, I addded an additive to my drum outside which holds the fuel. Because the deisel thickens up when it gets cold, which makes the heater have a harder time distributing the fuel to the heater. So far the heater has not kicked off.
Jan 09, 2009 | Coleman Propane Forced Air Heater...
I have a 15 year old Coleman Propane 130,000 Btu force air furnace, Model #BGU13020 forced air furnace. Afer the unit runs for 5 to 10 minuets, the flame will start to shuter and then it will trip the heat...
DO NOT attempt to repair this yourself. LP gas is a very unforgiving gas. Sounds like your heat exchanger is plugged. Yes it can be removed and checked, BUT it is not recommended. Trust your local repair tech. Any heater 15+ years old should be discarded.
Dec 26, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
524 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
