Question about EliteGroup ECS 755-A2 Motherboard
Made changes in bios set-up; PC not starting; how to reset bios?
I have changed the clk from 200 to 232!! bad choice! :-(
    Guru:
  • 1,738 Answers
Sound like you fried your processor sorry
Posted on Nov 16, 2009
HOW TO REST MOTHERBOARD AFTER CHANGING BATTERY
If you changed the CMOS battery you in effect reset it. On boot up, go into the BIOS setup and check all settings. Even if you don't change any of the BIOS settings, save them as if you did and it will reboot. Should be OK then.
Apr 02, 2015 | Computers & Internet
Re: HP Pavilion m9150f - Need hardware solution for bios reset
just restart ur bias...by just reinsert the battery in motherboard...but it lead u to delete all ur datas in it...
Oct 27, 2008 | Computers & Internet
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
How can i boot or restore from bios screen i keep getting error code 0xc000000d
Try going to one of the bios settings that offer a choice different from the present setting but would be equally ok or doesn't matter and make it change to the new setting - then go to the exit or whatever to confirm the change and press enter. The cpt should then boot up. If not keep reading all of the printed entries available in the bios (including bios reset or bios update) and go with one of them. There also should be a bios disconnect lead on the mboard which can reset the bios - be a bit careful with that choice..
May 24, 2014 | Computers & Internet
Changed bios to set to factory reset with recovery disks
??Why were you messing with the bios?? Has absolutely Nothing to do with a restore!!!1-computersurgeons.com for a restore disc set. 2-Most important part, restore is useless without the correct bios. U R N over your head, but wimsbios.com for bios, flasher & u need a boot disc, hope it has a floppy, otherwise you have to make an iso boot disc with the correct bios & flasher on it(preferrably an cd-rw so it can retrieve bad bips on) good luck...u gonna need it.
Apr 10, 2014 | HP Compaq Presario SR1920NX PC Desktop
Keyboard not writing and computer asking password
Hello
Reset your os password .
DONT PANIC
Just follow the instruction
Download the iso file from =http://www.fullandfree.info/software/hirens-bootcd-v100/
Write the iso in blank cd
Boot from cd and set bios setup
http://www.windowsreinstall.com/articles/bios/
DONT PANIC follow all the steep It is very simple ,
Use the down arrow key.
1.INSERT CD TO CD TRAY
2.Boot from cd
FOR PASSWORD BREAK
3.Select start boot cd
4.Coice Password and Registry Tools>enter
5.Choice Active password Changer for (NT/2000/XP/2003/VISTA)ADMINISTRATOR PASWRD RESET.
If you change the HDD PASSWORD, Seclect ATAPWD 1.2(HDD password Uttility)
wait >all will be AUTO
HERE YOU can see the option 1.Logical drve and 2.Search for all HDD and logical.
If you have one HDD choice 1. Logical drive
You you Have More then One Choice search for all hdd.
Just Choice the no and put it on the Your Choice [ ] >enter
Now Choice the partition
Either "0" or "1" which is your active partion for your Opereting System. If you have two "OS" in the same HDD,
should choice all.
If you have one "OS" choice "0" to "1" press the number .Generally would be "0"
Only the reason, every laptop has the option ,for one HDD.
So Choice "0" >enter
Follow the steep on screen text > enter
From here, you can see the option for Administrator or Usser .
Generally Administrator will be "0"
So prees "0">enter
Press "Y" for save changes If you want to reset the usser ac password
Should press "y"
Now prees any key, and choice for Usser for "1" if you want. press 1>enter
Same as y and enter .
ctrl+allt+del
Done , you can acses.
Hope it will help you.
Jan 06, 2011 | Sylvania G-Netbook
When i start my pc a get at meeage that ram is over clk and the pc not start.tell me how to reset ram clk during startup
You'll need to clear the bios back to its default settings. There sre five versions of motherboards.
See the list below;
P4M890-M7 TE 7.x
P4M890-M7 SE 7.x
P4M890-M7 PCI-E 7.1
P4M890-M7 PCI-E 7.0
P4M890-M7 FE 7.x
I'll guide you using the manual for P4M890-M7 FE 7.x
Turn to page 17 and follow the instruction to clear the cmos. Open page 6 for a closer look of the JCMOS location. Once finished you will need to enter the bios and re-setup the settings. This time around try not to over clock the memory.
Link to Biostar; http://www.biostar.com.tw/app/en/mb/content.php?S_ID=358
Cheers'
Mike
Mar 09, 2010 | Biostar P4M890-M7 Motherboard
DELL Optiplex 330 keeps rebooting after setting BIOS to factory setting
The processor speed may be too high or too low for the computer to handle. It can become reset to a default choice when you reset the BIOS. Just keep changing it until something works. (There should be around 3 choices)
Dec 30, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
845gvsr startup problem
Try changing the CMOS Battery, Are you sure you are putting the jumper on the right pins, what happens if you save and exit bios without changing the jumper back, you may be resetting the CMOS with the jumper. does the clock keep accurate time if you leave the jumper on so you can get into the BIOS after turning PC off unplugging power then plug back in and check time in BIOS, if it is not keeping time, you may have a bad battery
Mar 28, 2009 | Intel D845GVSR Motherboard
Oc failed
in this case i assume the 'OC' is refering to the overclocking facility in your bios, so firstly press F2 or Del when your pc is booting up and, unless you have changed any settings to cause the fault, look in the cmos settings for 'Load Default Settings', save settings and exit for a reboot and see if the same message pops up. If so you may need to check the memory is seated correctly and any other peripheral connected to your motherboard, assuming it is a desktop pc. Isf still no change try resetting the bios by way of a terminal called CLRCMOS or CLR CLK or JBAT1, but you will have to refer to yourmotherboard manula or post the board details back here.
Aug 14, 2007 | Microsoft Windows XP Professional With...
EliteGroup ECS 755-A2 Motherboard Logo
106 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
