How to remove codes
How do I remove a code that changes character when pressing the i or n keys
  • 3,594 Answers
Make and model?
DickyO
Posted on Nov 17, 2009
WE HAVE A SHARP ER-A610 CASH REGISTER WE WOULD LIKE TO CHANGE THE ITEM LABEL FOR EACH DEPARTMENT KEY BUT DON'T KNOW THE JOB # AND PROCEEDURE FOR DOING IT I DON'T HAVE ALL THE PAGES OF THE MANU
Sharp uses a 3-digit ASCII code for each character. The ER-A610 manual has a table of the codes, but if you've lost that part of the book, you can find ascii tables online, like this one:
http://www.ascii.cl/
Note that many of these show 2-digit codes; add a leading zero to those, so A is 065, B is 066, etc.
the 00 key on your ER-A610 has a special purpose here - it is used to enter each character's code, so to spell FOOD you'd enter:
070 00
079 00
079 00
068 00
where each of those double-zeroes is the double-zero key, not just two zeroes.
You need to know the number of each department you need to change. If you're not sure what order they're numbered in (It's completely customizable, so don't count on them being in order, unless you're sure.), print out your current department programming:
(In PGM1 or PGM2 mode)
1100 @/FOR CA/AT
will print out all the depts. CA/AT is the Cash key at the bottom-right corner of the keyboard. It stands for CAsh / Amount Tendered, which isn't exactly obvious, so some folks relabel it.
Note that on the tape you printed, the name is printed below the dept. number.
Now we're ready to start. In PGM2 mode, enter:
2114 . @/FOR (Is the decimal point after the 2114 visible here?)
[dept. number] @/FOR [character codes] SBTL
(etc. until done)
CA/AT
For [dept. number], enter the number on the keypad, not by touching the actual dept. key.
[character codes] is the sequence of 3-digit codes and 00 key presses, like the FOOD example above.
If the departments you're changing are sequential, life is a little easier. When you finish Department 6 (for example) by touching the SBTL key, it will automatically count up to 7. You can do a series of depts. by entering the first of them as above, then after using the SBTL key, go straight into the character codes for the next in line. Continue this way for as many are in series. You can jump ahead or back at any time by with [dept. no.] @/FOR and keep going from there.
SBTL in all the lines above, means the key that normally shows your subtotal including tax. It might be labeled #/SBTL. The MDSE SBTL key won't do the trick.
If you use PLU's in you register, their names are programed exactly the same, except that instead of starting with 2114, you use 2214. Simple, no?
Jan 11, 2013 | Computers & Internet
What is the ascii equivalent of that "window key" in the standard keyboard?
Hi there! Keys like the Windows key don't have an ASCII value. Only keys that are 'printable' have an ASCII value. To detect keys like the Windows key you have to use either the Key Down or Key Up events and use the Key Code to detect which key was pressed. You can find the values for Key Codes on MSDN
Hope this helps!
Sep 06, 2011 | Computers & Internet
I want to fax from new zealand to australia. how about i do it...........
In the setup you should enter your the fax number in the internationally standardised format, i.e.
in accordance with the following strict sequence:
??  The "+" (plus) character (by pressing
key)
??  Your Country Code( "64" for New Zealand)
??  Your local area code minus any leading "0"
??  A space
??  Your number on the local exchange, using spaces to aid readability as appropriate.
1 Press Menu/Set, 0, 3.
2 Enter your fax number (up to 20 characters).
Press Menu/Set.
3 Enter your telephone number (up to 20 characters).
Press Menu/Set. (If the telephone number and fax number are the same, enter the same number again.)
Note
??  You cannot enter a hyphen in the number.
To enter a space press once between numbers.
??  The telephone number you enter is only used for Cover Page features.
4 Use the dial pad to enter your name (up to 20 characters).
Press Menu/Set.
5 Press Stop/Exit.
Note
If the Station ID has already been
programmed, the LCD will ask you to press 1
to make a change or 2 to exit without
changing.
3.Station ID
??²
Now dial the fax number of australia 0061............ and send fax.
Jun 02, 2011 | Brother IntelliFax-2820 Laser Fax
How do I get swedish letters on an asus keyboard?
You get special characters by using alt codes. That is, you press and hold the "alt" key while entering a 4-digit code using the numeric keypad (or, on a laptop, the keys that serve as a numeric keypad). When you release the alt key the special character appears at the cursor location. This page lists the characters and corresponding code.
If you are using an application like Microsoft Word, there may be an "insert special character" command available. Then you can pick the character from a table instead.
Mar 04, 2011 | Computers & Internet
Ibm wheelwriter 3 prints unrecognizable characters
Sounds like you have tried all the easy stuff. I'll guess that the gear on the selection plate is loose from the shaft. No easy fix, you may be better off buying a replacement on ebay they get pretty cheap.
DickyO
May 01, 2009 | Lexmark Wheelwriter 3 Typewriter
Wordsmith 100 Wrong character typed.
Your keyboard assembly needs to be replaced.
Jan 14, 2009 | Smith Corona Wordsmith 100 Typewriter
Error code: H 4 flashes.. Nothing works
H4 PRESS START KEY THERE WILL BI A SUB CODE LIKE 00.THAT IS HEATER UNIT TEMPERATURE PROBLEM.RESET IT BY THIS PROCEDURE.
PRESS CLEAR KEY,AUTO PHOTO MODE KEY,CLEAR ,AUTO PHOTO ,
COPIER DISPLAY DEAD 14 START KEY.
PROBLEM REMOVES
BY MIAN JEE
Oct 23, 2008 | Sharp Office Equipment & Supplies
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
CHR SIZE AUTO?
Press the Return button and the machine will automatically print the size the tape will allow! :) Title:
What does the error message "CHR SIZE AUTO?" mean? Description:This message appears when the selected character size is too large for the width of the tape cassette installed.
You have the following options:
  • Press the "Print" or "Return" key to allow the P-touch machine to automatically select the maximum character size that fits the tape width.
  • Press the "BS" key to clear the message, and then install a wider tape cassette.
  • Press the "BS" key to clear the message, and then select a smaller character size by following these steps:
    1. While holding the "Code" key, press the "Size" key. The display will show the current character size.
    2. Keep the "Code" key held, and press the "Size" key until the desired size is displayed.
      If you select "AUTO", the P-touch machine will automatically adjust the character size to the largest possible size.
    3. Release the "Code" to apply the setting.
If you have the correct size tape installed and still get the error message, please try removing the cassette from the machine and reinstalling it. Also, check that the tape cassette is seated firmly in the compartment.
Note
    The following table shows the maximum character size that can be used with each tape width.
    Tape Width Maximum Character Size 1/4" (6 mm) 12 points 3/8" (9 mm) 18 points 1/2" (12 mm) 24 points 3/4" (18 mm) 42 points
Related Models PT-1900
Feb 17, 2008 | Brother P-Touch 1900 Label Printer
Open Questions:
43 people viewed this question
k24674
