Question about Weber Spirit? E-310 Propane Grill
In June I bought a new Weber grill but the auto ignitor does not work--there is no click--therefore no spark. I can light the grill manually.
  • 388 Answers
If there is no click, it is most likely the igniter module is bad. The igniter module should be available at any Home Depot or Lowe's; in any case, your owner's manual will show you how to remove and replace the igniter module. If you don't have the owner's manual, I will include a link to one online; you will need Adobe to open it. Here is the link: http://www.bbq.us.com/images_templ/weber-manual-3741001.pdf
Try this and if it doesn't fix your problem, come back and let me know and we will troubleshoot further. Good luck!
Posted on Nov 17, 2009
Grill was lit and when I went back to check it was off and i can't get it started, just clicks, seems like the starter.ignitor is broken?
Did you try to light it with a match? If it lights, then you have propane. If the ignitor is :clicking, usually it is sparking also.
Jun 04, 2011 | Weber Spirit? E-310 Propane Grill
I installed a new 7509 ignitor on my 13 year old weber genesis gas grill and the gas does not ignite when pushing the ignitor button. I installed the ignitor with the box opening on the bottom and checked...
If the spark you see is in the ignitor box and not at the burner(s), then there's a wire loose somewhere or the ignitor is not grounded properly. Also check to see if the ignitor tips in the grill next to burner(s) are covered with grease. If so, clean them with a cotton ball dipped in alcohol. Check each ignitor wire at each ignitor , make sure they are secure,
Feb 20, 2011 | Weber Genesis Silver B Grill
My grill became hard to light & now will not light. I took it apart and cleaned it & noticed that the box around the igniter is all coroded away. How does this get fixed?
In the case of your grill's ignitor control box, it will have to be replaced. You can order one online. directly from Weber. Just be sure that you have the Model # & Serial # available. It's an easy replacement to accomplish. The new ignitor control box will come with the instructions or you can find them in your Owners Manual.
Happy Grilling!
Jan 23, 2011 | Weber Genesis Silver B Grill
Summit ignitor Worked fine yesterday, today no ignitor.
Check your ignitor wires for broken or disconnected connections.
May 14, 2010 | Weber Genesis Gold B Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
Ignitor on performer grill stop working. Can
Call Weber at 800-466-1071 and order the ignitor kit: http://www.weber.com/publicSchematic/view.aspx?model=841004&Sequence=26&Suffix=
Aug 22, 2009 | Weber Performer Grill
Weber q 200 all of a sudden won't ignite- just clicks away
Most ignitors work of a battery which makes it spark. find the battery and replace it
Apr 20, 2009 | Weber Q Grill
Burner won't light
Clean everything up with a wire brush. The tiniest bit of debris in the ignitor area will prevent a spark.
Mar 09, 2009 | Weber Genesis Silver B Grill
Gas grill ignitors
Check the electrode.  That is the end at the burner.  It may be corroded and no longer creating a spark.
Jun 05, 2008 | Weber Q300 Grill
Weber Spirit? E-310  Propane Grill Logo
1,011 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
