Question about Canon imageRUNNER 1310 Copier
We have a drum that doesn't want to go back into our Canon Imagerunner, Help!
    President:
  • 1,126 Answers
The drum unit and toner/developer unit must be securely latched together. It is not uncommon for the rear side to become loose from each other. Reconfirm propper attatchment of these two units and try reinstallation. Please let me know.
Posted on Nov 17, 2009
Hi i have ir3300 and the print is lighter from one side in a4 sheet
First of all You need to clean the laser unit and beneath the copy glass and lenses inside.
Second of all if cleaning doesn't help's try with cleaning the developing roller and replace the drum unit and transfer roller.
Hope that helps
Sep 09, 2011 | Canon imageRUNNER 2200
Error code 100. On canon image runner 2000
You need to change the drum unit and turn the copier off and on. Drum unit C-EXV5.
If the drum unit doesn't helps, replace laser unit.
Sep 08, 2011 | Canon imageRUNNER 2000 Copier
How to take out canon imagerunner 400s toner?
hai,
remove the drum unit from the copier
open the plastic flap of back side on the drum unit
tack out the waste toner
then close the plastic flap
best of luck.
Feb 22, 2011 | Canon imageRUNNER 400S Copier
HOW DO YOU REPLACE THE DRUM IN A CANON IMAGERUNNER IR1600 COPIER
do you mean complete drum unit?
If yes, you need to open front cover, realese the blue handle, remove the left sideway cover ( cover above the bypass tray, that have handle in the middle and goes out in left direction - TRANSFER COVER ), you will see two handles, left and right of the drum ( green roller ), grab them and pull the drum unit out.
Reinsert new drum unit, put back the transfer cover, lock the blue handle and close front cover.
Hope that helps!
Aug 23, 2010 | Canon ImageRunner 1600 Copier
How do I change the drum in my Canon imageRUNNER 210S?
Open front door>turn down green handle>remove thumb screw on grey cover>slide out drum unit>unpack new drum>slide back into area where old drum was removed>reinsert thumb screw>lift green handle>close door.
Aug 11, 2010 | Canon imageRUNNER 210S Copier
HOW DO WE CHANGE THE DRUM CANON IMAGERUNNER 1370F
remove toner out,
slide cover in left side,
pull out the drum unit by metal wire hinge,
on top of the drum are two blue handles wich you need to realese,
put in new drum,
lock again the two blue handles,
put it back in ( drum unit ),
slide cover to right,
put back the toner.
Hope that helps!
Jul 29, 2010 | Canon ImageRUNNER 1670F Copier
Canon ImageRunner C2058: Repeated noise in image. Drum issue?
The upper fuser roller is probably worn out. If the spot is of a particular color, then it may relate to that drum unit.
Jun 21, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
May 28, 2009 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 1310 Copier Logo
77 people viewed this question
old marine
old marine
