Question about Miele Inspira G2140 Dishwasher
Warped cabinet door next to dishwasher
The cabinet door next to the dishwasher is warping, i notice quite a bit of warm moist air inside the cabinet whenever the dishwasher is running
Our Bosch dishwasher always has condensation after completing the cycle. Is there a reason for this?
I have noticed the same with our bosch dishwasher. Once the unit finishes washing, it sits there silently for about 1/2 hour and then exhausts the hot/moist air through the drain pump and illuminates the "clean" light. With the tub still hot, I open the door and prop it open a few inches with the top rack for a few hours. Since the tub is still very hot but open to the much cooler air, a lot of that condensation will leave the clean dishes. A few hours or even overnight should do the trick! It isn't a perfect system but beats having that coil heater in the bottom to warp all of your plasticware.
Aug 13, 2017 | Bosch Dishwashers
How to bend plastic back into shape
you will need some sort of mould and a warming oven to get it right
better to buy new drawer set
Jun 27, 2017 | Dishwashers
Electrolux Built in freezer door not closing.
I'm suspecting the door also because of the lack of suction power. you have to check the gasket more. Frost around the door is a great indication of where warm moist air is coming into it.
Aug 14, 2013 | Refrigerators
Frig door does not stay closed
When you say that it will not stay closed, what exactly do you mean? That the door seal does not meet the cabinet, that there is a gap? Is the door warped? Does it appear to be out of line with the hinges on the top and bottom? Is the space around the door when shut and looking at the front pretty much equal all the way around? I mean, when shut, does it appear that there is about 1/4 to 1/2 inch of the cabinet showing all around the door when shut? Has someone swung or leaned or tugged on the door, or closed the door or tried to close the door and something was keeping either the top or the bottom pushed out? There are adjustments on the hinges, at the attachment points to the cabinet and to the door itself. You may be able to adjust the hinge plates in or out and up and down to make the door seal better. And the box should be about half a bubble out of level, front to back, or with a slight angle front to back, in order to help the weight of the door seal to the cabinet of the refrigerator. If the door is warped, you may be able to determine which way it is bent, out at top, out a bottom, side to side, ect. and take it off the hinges and gently attempt to straighten this bend. If you are careful, and can determine there is warping at the top or bottom, you may be able to "straighten" the door while attached to the hinges. Gentle pressure is the procedure, GENTLE, GENTLE. Don't get the BIG HAMMER out and go to banging away. Just a push up here, and a tug down there, and you may be able to cure this fairly easy. You must first determine which way the door is warped, and then move it back the other way. It should seal the gasket to the cabinet, not so much attach the door to the cabinet edges, but a firm seal that takes a tug to open. And no air gaps. Are the products inside the refrigerator "sweating". This is the drawing of warmer room air into the cabinet and condensation forming. The door needs to seal in order to keep the cold air in, and the outside air OUT. I an extreme warping, you may have to replace the door, or use bungee straps to keep it shut. which will be a pain, removing those every time you need in it. I would try and determine where it may be bent or warped, and gently bend it back the other way a little at a time till I have the seal connecting all the way around. Once there, QUIT. No more bending. When the seal connects all the way around, you are finished. Problem solved. I wish you luck and hope that you can solve this fairly easy. Remember, be Gentle. It will warp easily. And no hanging on the door!
Sep 26, 2009 | Sub-Zero 680 / F
The oven is producing a ton of heat on countertop next to stove and in cabinets
I'll look for open gap on the door, you may have a bad oven door gasket door ajar or door may be warped.
Sep 09, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
I have just recently noticed a black mouse and it always seems to go back underneath by dishwasher but i have a Frigidaire Ultra Quiet not a Maytag. Could the mouse be living inside of it?
I'll be he's just hanging out underneath...hey it's warm under there... There's no way he could be getting IN the unit. Remember the dishwasher cabinet is a sealed unit...it's gotta keep the water inside w/o leaks... with the door closed, that is..
There's a little space under your dishwasher that's a great mouse house... eek!
Jul 21, 2009 | Dishwashers
Frost build up in freezer and warm temp in a GE Profile TFX22PRXB
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal. Your refrigerator most likely has a defrost timer located on bottom behind grate, or inside behind control panel. Could you find the correct model number so I can help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 24, 2009 | GE Refrigerators
Door warped.......
Hi, These cabinets have 2 sheets of tempered glass with an airspace between and are fully reversible I would doubt they are warped. My best guess is that the cabinet is not square. If you have a level, check it across the top of the cabinet not the door. Also check it diagonally both directions. The cabinet has feet which are adjustable unless you have a low spot on the floor for which you may have to use a shim. Remember that it needs to lean slightly to the rear for the door to close on its own if partially open. Good Luck to you! Let me know how this works for you.
Feb 08, 2009 | EuroCave Comfort 260 Collector's Package...
Dishwasher insulation for heat
Hi marseibold,
I'm Harvey the Master Plumber.
Your questoin is: You're wondering if you can further insulate your dishwasher for heat. You are redoing your kitchen, new appliances, cabinets, etc. and shortsightedly put the spice sliding pull-out cabinet next to the dishwasher. The spices get warm when you use the dishwasher. There is a bit of room between the cabinet and dishwasher. Any recommendations for further insulation?
Yes. I would get another insulation blanket off a d/w I'm disposing. Anyway, you need to get one and install it over the old one to decrease the heat transfer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
The freezer door on our GE side by side fridge does not shut tightly in the center of the door causing a frost and ice build-up on the outside of the door, ( in the inside edges. We have been told that...
There are ways to adjust the hinges, and loosening the screws on the plastic door liner will allow you to "warp" to door a little bit in an effort to get it to line up flat and square to the opening. Sometimes the gasket gets folded up on the hinge side and won't let the door close properly. If you try these adjustments and the door just can't be fitted nicely, you have a serious ploblem. Use something straight to see if the cabinet is warped or if it is the door that is warped.
Jul 23, 2008 | GE Refrigerators
Dishwashers Logo
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
