Question about ASUS K8V-MX Motherboard
Motherboard can not detect dvd rom help
Hi there the motherboard detects that the dvdrom is there but when i put the xp disk in it will not read the disk. I have tried the rom in my other comp and it works fine help me please!!!!!!!!!!!!!!!!!!!!
  • mattyc_92 Dec 01, 2008
    i am studying ict systems support and i cant remember a thing i need help... this is the question
    Inorder to assess the potential of a donated system unit, as received, forrefurbishment or upgrading you need to know what components are necessary toform a basic working system unit, as well as being able to identify whatcomponents are missing or what other devices when added would improve systemperformance or versatility.
    Usingthe Personal Computer components list below explain the function of each of thecomponents listed and explain how each component communicates with theprocessor and/or connects to the motherboard. Use images or pictures asappropriate to aid the text.
    Personal Computer System Unit Componentsfor Task 1
    • DVD-ROM or CD-RW Drive
    • 64-bit Sound Card or 128 Mb Graphics Card
    • 56K V90 PCI (Internal) Modem or 10/100 Mbps Network Interface Card
    • At least 1 Serial Port, 1 Extended Parallel Port and 2 USB Ports
    • Two peripheral s: ( selected from printer, webcam, plotter, microphone, speakers, or scanner)
    Genius:
  • 1,067 Answers
Try changing cable is it set at master on jumper for end of ide cable and if its middle dvd rom drive its slave set jumpers to slave ok try changing cables clean yo cd
Posted on Jan 09, 2008
Greeting I just bought "LG
Greetings... I think your having a problem with your hardware DVD R/W.
based on your observation...
1) The dvd rom drive is detected on your windows xp and by pushing open/close button still working... " this indicate that the power and SATA / IDE cable was properly connected.
2) And you've said "NOT SPINNING".... "means you have undergo testing by touching or listening DVDrom drive while the disk was inside after closing the disk tray which is right"
Therefore your DVDrom drive was defective... you can also check by opening the metal cover to see if the disk was spinning and if the laser of optical lens released a red light.
Jul 12, 2011 | LG GSA-2166D DVD RW Dual Layer Burner
At first my computer cant detect my Maxtor HDD. but when i connect the sata port as a slave , it can detect the HDD. but after that it is showing " Disk but failure...." or " Disk read...
Restart the system and then press delete key when the computer start up then set the first boot to CD/DVD ROM then press F10 (save) and follow the instruction "press any key to boot from CD/DVD ROM after that First try to repair and if it's not satisfy. Please to format your Hard Disk
Hope it'll be helpful to you
All the Best!
Jun 30, 2011 | Gigabyte GA-945GM-S2 (0818313003065)...
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
IDE controller not working properly
having done these things get in touch and we will go from there
Nov 01, 2008 | Intel D101GGC Motherboard
Cd/dvdrom light is blinking all the time
Check first under my computer/computer if you can see the DVD/CD Rom drive.  If not detected, follow the steps on this link...
http://support.microsoft.com/kb/929461/en-us
It should work fine after reboot.
Hope this helps
Sep 12, 2008 | Compaq Presario X1000 Notebook
DVD/CD rom drive issues
Hi, it appears that CDW/DVDROM is only detected in BIOS but in normal windows. This is a known issue from Microsoft eventhough you are using Windows Xp or Vista the CDW/DVDROM is not detected and does not appear in My computer icon. This can be easily fixed by a registry tweaks.
Please click on this link http://support.microsoft.com/kb/929461/en-us and then delete the upper/lowerfilters which is blocking the CDW/DVDROM to appear on your windows.
Hope this helps!!!
Thanks
Sep 05, 2008 | Compaq Computers & Internet
Cd drive problem
Hope this helps!!!
Thanks
Jul 13, 2008 | E-Machines emachines (emachinees) CD-ROM...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS K8V-MX Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
