Question about Canon Office Equipment & Supplies
How to print to fax using the canon imagerunner 2020i
  • 318 Answers
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Posted on Dec 09, 2009
2 Suggested Answers
babaprithi
  • 372 Answers
SOURCE: I have a canon imagerunner 2020I copier with a
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
Posted on Jul 15, 2011
Jul 13, 2011 | Canon ImageRunner 2020i Copier
Hi, I need help setting up the scanner on my canon 2020i.
Hi, How to set up the scanner on canon 2020i?
By Subbaramaiah, Kurnool
Mar 28, 2011 | Canon imageRUNNER 2020i Black and White...
We have a Canon 2020i printer/copier. We are having a hard time printing address labels and it keeps saying "load paper", no matter what instructions we give the machine!!
Pull out paper cassette and look where it enters, check whether the paper sensor is healthy, if broken replace it. Paper sensor is black and is like a hook
Jan 31, 2011 | Canon imageRUNNER 2020i Black and White...
We have a Canon Imagerunner 2020i and all of a sudden our copies are coming out offset and the screen says wrong size paper. We are using 8.5x11 paper for 8.5x11 copies.
Check the dial or slider on the side of the cassette tray for size indicator. This will cause jamming and the improper size message. Make sure the indicator matches the size of paper in the tray.
Sep 16, 2010 | Canon ImageRunner 2020i Copier
Display screen is blue wont turn on canon image runner 2020i
In most cases is that system software is colapsed. The problem is when you turn on copier nothing happens with machine or display and you cannot copy or print.
Upload the system software, language,... for this you need service support tool, so call service.
Pls. rate
May 10, 2010 | Canon ImageRunner 2020i Copier
My Cannon Imagine Runner 2020i is sending faxes fine but isn't receiving faxes at all.
Could be a phone line problem, may not be set for English in the service mode. There could be another device on the phone line. Dial the fax and see if you here it responding. Plug a phone in the fax wall socket and call someone and be sure both of you can here each other clearly.
Mar 09, 2010 | Canon ImageRunner 2020i Copier
first do you have to selec the try with do you are going to use for copy.
Jul 27, 2009 | Canon imageRUNNER 2020i Black and White...
Canon image RUNNER 2020i is flashing Error code E000808 after trying to print labels...what's up???
E808 A fault in the fixing drive circuit or the power supply unit is
detected
check the fixing rollers maybe some adhesive materials left on the roller and cause the fixing roller not to rotate smoothly. or some drive gears broke during printing on heavy media
Jul 02, 2009 | Canon ImageRunner 2020i Copier
160 people viewed this question
old marine
old marine
