Question about Epson Stylus 2200 InkJet Photo Printer
Put in new cartidge and now it says all are empty and they all need replacing. I change that one color and it still says they are empty
  • 3 Answers
I had the same problem. Make sure your printer is off when relacing cartridges. If you already replaced them, turn your printer off, remove cartridges and put them back in, then turn the printer on.
Hope this works.
Posted on Nov 23, 2009
Hy everyone.I've got a problem.I am having canon pixma MP190 and when i click "Print" the printer shows "The following ink cartidge cannot be recognized : Color".Please i need help !
antonyo,
is there an error code, i know with cannon it has to be there cartidges or you will get and error code( as in a #) now i also remember that on a canon both cartidges have to be in machine and in the correct slots and in a tight position. try hitting ok on printer and see if it prints even though you get an error message that would tell me it is bypassing the ink cartidge and then if i were you go back through the steps i the manual for replaceing an empty cartridge with a new one .
hope it helped
Sep 29, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Error message "remove and chech color cartidge". I removed and replaced it several times and the same message appeared. I used a new cartridge and the same messade appeared. What can I do now?
you either have a cartridge that is empty or it is damaged, remove both print cartridge and try and put them in again. Unplug the power cord, insert it and start again
Sep 09, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Apr 27, 2010 | HP Color LaserJet 2600n Printer
Message in LED is ''Remove and check color cartridge''
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Can't print black/white photos
Actually there is no solution to this "problem" nearly for all Inkjet machines.
The reason is that Printers are Dummy Receivers, meaning that they can not process the print file, sent to them by any source. They are programed to just print the file without "asking questions".
The Manufactures now, of Inkjet machines, in order to avoid the possibility of printing something with a certain colour missing, they have just programmed their machines NOT TO PRINT ANYTHING whenever ANY colour is empty.
So, dont bother trying to print making all kind of adjustments and change settings and get a new cartidge :)
Rgds LukasCY
Jan 04, 2009 | Office Equipment & Supplies
Mfc-240c reading offline and empty black
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Sep 24, 2008 | Brother Multi-Function Center MFC-240C...
Printer won't process new catridges. These cartridges have been refilled.
Did you install the original cartridge? if you have the old empty cartridge, try to install it and check the error is empty cartridge..if so the problem is the newly installed cartridge. try to buy the new original one.
Dec 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
C4180 Professional Photo Pack
Yes, plastic cartidge holder is provided to you to store HP 337 (black inkjet print cartridge) as you remove it to install a new HP 338 ( Photo Cartidge).
Remember, below combination of Cartidges for used for specific purposes:
Black and color cartidge  for general Printing of Documents.
Black, Color, Photo Cartidge to Print Photos.
Color cartidge , photo Cartidge and gray cartidge is specially used when you to print copies of photos  with great quality.
I hope that this should resolve the issue for you.
You can mail me at thumuvikram@rediffmail.com for further assistance, I'll be glad to help you.
Bye
Oct 16, 2007 | HP PhotoSmart C4180 All-in-One Color...
Epson Stylus 2200 InkJet Photo Printer Logo
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
