I have a wireless router that had been working fine. It first belonged to my mom, but when she moved to a bigger house, I got the less powerful router for my apartment. I set up a new network after resetting the machine and my wireless was golden for four months, then one day, when I tried to access the Internet wirelessly, it wouldn't connect, and when I went to check the router, the WAN light and all the LAN (1-4) lights are on (and solid - no blinking), but the power and status lights are not on at all. (This happens no matter what is plugged in - currently, just the power cord is in.)
So far I've already tried resetting it, but that hasn't worked. I can't even get access to the machine through the default IP address.
-   i have exact same problem,no matter how i do,unplug ,resetting ,put power back,still same thing with wan led and 4 local network led on butpower nad status off,anyone have any idea
-   Guest
May 30, 2008
-   I have the same problem Wan Light On and Lan 1-2-3-4 Lights on.
-   Wildwonder
Mar 30, 2008
-   Same problems no power and status lights. WAN WLAN 1,2,3,4 all solid on.-   Guest
Try unplugging the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc. I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?) Also, there as one firmware update, which had a mistake, that set the router IP to 102.168.1.1, rather than 192.168.0.1. Good luck!
Was this helpful?
Yes
No
Popular Solutions for D-Link DI-624 Air Plus XtremeG
Basically we've tried the put in our IP address into the browser adn got into it, we've also changed...
(More)
Basically we've tried the put in our IP address into the browser adn got into it, we've also changed the DMZ as another solution said, UPnP is enabled, etc. but xbox live still tests as strict NAT HELPPPP!
This is a home network. The DI-624 will disconnect users at multiple times during the evening hours,...
(More)
This is a home network. The DI-624 will disconnect users at multiple times during the evening hours, not as much during the daytime. The log reads Dec/20/2008 23:51:56 DHCP lease IP 192.168.0.102 to xxxPC01 00-1c-df-59-ec-9b Dec/20/2008 23:51:50 DHCP lease IP 192.168.0.100 to xxxPC01 54-34-4c-3c-7f-04 Dec/20/2008 23:51:45 Wireless PC connected 54-34-4c-3c-7f-04 Dec/20/2008 23:51:44 DHCP Request success 192.168.2.2 Dec/20/2008 23:51:44 DHCP Request 192.168.2.2 Dec/20/2008 23:51:43 DHCP Discover Dec/20/2008 23:51:39 Wireless PC connected 00-1c-df-59-ec-9b Dec/20/2008 23:51:39 DHCP Discover Dec/20/2008 23:51:37 DHCP Discover Dec/20/2008 23:51:37 System started This may happen five to ten times during the evening and is very disruptive. Any help would be very appreciative.
