Question about Gaggenau ED 220/221 Electric Single Oven
I have a code 40 on my oven after running it in the cleaning Auto Pyrolysis. How do I reset it?
  • alkrelnikov Nov 16, 2009
    I don't have phone number for this. The code F 40 is on steady and the key sysmbol is flashing. Does this mean more of a lock problem than a probe problem?
  • Gaggenau Master
  • 19,396 Answers
Hi.
Unfortunately Gaggenau does not make available error codes list and technical documentation.
To reset the oven you simply trip the circuit breaker.
If that does not clear the error, then there is a fault, contact Gaggenau at the number listed on the owner manual.
Parts that may get damaged after self cleaning are temperature probe, door lock, and EOC.
Regards.
Posted on Nov 16, 2009
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
How do I end auto clean
try to unplug it from receptacle for 1 hr the reconnect to reset chip
Sep 16, 2014 | Ovens
Neff B4562
Engineer is a solution.
The other solution is;
Switch 3 times between rotisserie and pyrolysis or bread baking setting and pyrolysis.
As acknowledgement the displays are actuated.
At each change of operating modes switch immediately stops the current test step and the next step of the test enabled. The oven light should according to the mode ON or OFF; that is, at pyrolysis OFF otherwise ON.
Jul 01, 2012 | Ovens
How do you clean a self-cleaning gas oven?
If it's one with pyrolytic oven coatings then you empty the oven and turn the oven to maximum for about three hours.
The linings will get hot enough to burn deposits to a light ash residue which you can then wipe off with a damp cloth when the oven has cooled down.
Some modern ovens have a self-cleaning setting on one of the controls. All it does is to automate the process and to lock the oven door until the cycle has completed.
Note that you will smell the fumes as the oven self-cleans and they can set off any smoke alarms you have. Also, if the oven is really filthy and thickly caked in grease then the pyrolysis will not be fully effective. Note that oven shelves and other metal fittings and also door glass are not pyrolytic and any deposits will get baked on, so clean those separately first. Really stubborn deposits will come off using a caustic-soda based cleaners, but you must wear suitable protective gloves, glasses and clothing and exercise extreme care when using them as caustic soda burns are far, far, worse than acid burns.
Jul 09, 2011 | Whirlpool SB160PEE Gas Single Oven
I tried to auto clean bottom oven. Showed err
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 05, 2010 | KitchenAid KEBC208 Electric Double Oven
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
Whirlpool Gold AccuBake - Auto Clean does not work
The cost of fixing this will be anywhere from 50-200 dollars. There are several variables here. The big expense comes in labor. With one this old, I would just live without it or you just have to have a self clean, go ahead and but a new one for about 400-450 dollars. You are looking at the last quarter of the oven's life anyway especially if you use it a lot. Fortunately for you, the oven still works fine without it.
Feb 22, 2009 | Ovens
Bottom oven door won't open
Started the pyrolysis cycle for 1 minute and then cancelled it. The door then unlocked.
May 25, 2008 | Gaggenau EB294/295 Electric Double Oven
Gaggenau ED 220/221 Electric Single Oven Logo
102 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
