Question about Toshiba Qosmio G15 Notebook
How do I remove the invertor from a Qosmio F20?
  • Toshiba Master
  • 32,281 Answers
The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
Once the bezel is removed then you can get access to the inverter to remove it.
Posted on Nov 16, 2009
  • 458 Answers
Once you remove the screws(if any) from the front bezel of the screen, you will need to use a tool such as a guitar pick or similar to UnSnap the Bezel Locks around the Whole front Plastic Bezel... Gently pulling the front bezel away as you unsnap the front cover...
you will now have access to the Inverter.. it is located under the Screen.. it's the Long Rectangular Circuit board... You will need to unplug the Display cable conection from it and unplug the LCD Bulb plug from it... If it is attached to the underside of the screen, you simply remove the 1 or 2 screws on the inverter, bend the tab on the end of the inverters holder and slide the inverter out.. If its just held down by 1 screw to the back of the screen - simply unscrew the 1 screw and remove the inverter...
2 Suggested Answers
  • 94 Answers
SOURCE: How do I remove the invertor from a Qosmio F20?
The easy option is to Disassemble, i recommend you give it
  to a technician.
Fan noise qosmio f20
You can use a can of compressed air or an air compressor to clean it, or you can also use a vacuum with a hose attachment to clean it. Or you can use any combination of the three.
Aug 14, 2012 | Toshiba Qosmio F20/F25 CPU fan - TS36633
Lost bios password thoshiba qoasmio f20-155 laptop
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 24, 2010 | Toshiba Qosmio G10-133 Notebook
Average kilowat consumption of a Toshiba Qosmio
Minimum (everything off and/or on minimum): 31.8 Watts
Idle (max. brightness): 42.1 Watts
Maximally (full load inclusive. WLAN): 64,8 Watts
May 25, 2010 | Toshiba Computers & Internet
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
  to a technician.
Nov 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
My laptop screen will not turn on. The laptop turns on & I hear it working, the screen will just not turn on.
Hi
This sounds very much a backlight or invertor issue and will need to be replaced. If it is the backlight then a screen replacement at about £140 is a rough guide. IF its the invertor then they tend to range from £10 to £40 and really both jobs should be done by a reputable computer retailer.
Thanks
Taz
Nov 02, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Card slot not working on qosmio f20
There is. You'll need to download it from Toshiba's support page. Try this link:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835451&rpn=PQF10U&modelFilter=F15-AV201&selCategory=3&selFamily=804517&selModel=835451%7CPQF10U
Click the Downloads tab, and where it says Refine Search By: click the All Categories drop down menu, select SD. Run the donwloads available there.
If the above link didn't work, use this one:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
Feb 13, 2009 | Toshiba Qosmio G15 Notebook
Sound and itunes
start install itunes again , it show options then click remove from that it will uninstall , till the problem is same use third party software to unistall i refer cc cleaner its free download first uninstall the itunes and restart the system then sound will works i think so
Mar 25, 2008 | Computers & Internet
Toshiba Qosmio G15 Notebook Logo
192 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
