Magnavox plasma tv loses both picture and sound
I have a 42 " Magnavox plasma tv. About every other time I turn it on, it ends up losing both picture and sound. While the 'power' indicator stays on, the only way to temporarily fix the problem is to unplug the tv, so it can reset. The problem may occur again within 30 minutes, or it may not happen again until the next day. Any ideas?
  • DaveVirginia Sep 16, 2008
    42 inch Magnovox picture is lost, but sound is okay.  It's not the cable.  I reset.  The picture is dark with lines of color and picture trying to come through.
  • gitgot Jan 04, 2009
    My Magnavox model #42MF230A/37 does the exact same thing and is exactly about as old as yours. We bought it in 11/06. No solution....
    No help from Magnavox.....
SOURCE: Pioneer Plasma
maybe you can bring it at any pioneer service center and have the IC's reprogramed.you can try that...
Posted on Mar 12, 2008
SOURCE: Magnavox 30MF200V/17 No picture, only sound
Do you know if i can use an inverter from any LCD tv, or does it have to be specific to that model? I was thinking about taking an inverter from another broken TV.
Posted on Jun 23, 2008
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
tvguy171
  • 106 Answers
SOURCE: Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Posted on Nov 26, 2008
SOURCE: 42" panasonic viesta plasma tv cuts off after about 30 minutes
Adjust the automatic shut off settings on the set using the menu system. the newer models are programmed to shut down to avoid the burn-in problem associated w/ plasma scenes.
Posted on Dec 30, 2008
The TV turns on and shows a picture that you can watch and within 10 minutes the TV loses its picture, however, the light is still green. If you turn the TV off you can get the picture to come back after...
The issue here could be a capacitor within the power circuit. Also could be a power transistor that is faulty. On the easy part it could be a matter of reprogramming the unit but I doubt it.
Dec 18, 2017 | Hitachi 42HDT52 42 in. Plasma HDTV
My Pillips 42" TV works
Is this a plasma TV? I have worked on several of these. Please provide the model number so I can better help you.
Mar 23, 2011 | Philips Televison & Video
42 in. magnavox flat screen wont turn on
Does that mean, you still have sound but don't have a picture?
Nov 09, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
May 06, 2010 | Samsung HP-T4254 42 in. Plasma Television
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Jan 27, 2009 | Televison & Video
Magnavox 42MF 230A- just over one year of use but out of warrant
I have a magnavox 42 MF 230A, It is showing a 2 in vertical line in the center of the screen
Nov 10, 2008 | Televison & Video
I have no audio on my 42" Samsung plasma tv
This happened to me also. It had to be taken apart. The audio connector on the motherboard had come lose. Hope this helps.
Dec 04, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
