Question about Jensen JCS-600S (14 Channels) 2-Way Radio
I have one set of this model. if I buy another set, will they be compatible with each other frequency-wise?
    President:
  • 2,761 Answers
Absolutely. The frequencies are assigned by service (e.g GMRS), not by individual radio.
Posted on Dec 05, 2009
Where can I get a replacement outside sensor Z31092-TX for my Auriol weather unit.
possibly from the manufacturer .worst case will be to just buy a totally new unit , as the sending units have to be matched frequency wise
Jan 03, 2018 | Measuring Tools & Sensors
Hi. my wife bought a dualit toaster online and had it sent to australia. ios it compatible? what can i do to make it compatible. bought through myhabit
All you need is to match the voltage and frequencies. So you need to check if the toaster is 220'240V and 50hz. If not it is better to sale it back on ebay and buy the same model with above voltage. In order to make it compatible you will need a transformer and the cost for the transformers is depends on the watt and for 2000W it will cost 120-140 $
Aug 31, 2011 | Dualit 40352 4Slice Toaster
Does this model support PAL color system? I misplaced my user manual and i am unable to change settings.
Where did u bought this LCD tv,if u buy it in the US,Mexico or Canada no it only work with a NTSC signal frequencies.If buy in Europe,Asia,Australia,Middle East or Africa.Yes,it will work with PAL signal frequencies.
Dec 06, 2010 | Televison & Video
Monitor displays frequency out of range.....need help . How can I solve this?
The frequency is out of range because the VGA graphics card is not compatible or set right for the monitor's set of frequencies that it can work with.
Try another VGA graphics card.
Or upgrade the card to one with DVI, and upgrade the monitor to one of those 24" DVI Samsung monitors. They're nice. I got one from Best Buy a few years ago, and never regretted the larger desktop.
Good luck on this one.
Jul 10, 2010 | E-Machines eMachines Monitor E15T4
Can you change the operating frequency of a Samson
No, the Stage 5 series are fixed-frequency units. They come in a variety of channels (the new 200Mhz range model has 28 different ones) but they're factory-set, and not programmable, so the frequency you pick when you buy one is the frequency you're stuck with.
Apr 07, 2010 | Samson Stage 5 / CO5 Professional...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Make different frequency memory modules working together
if the memory not the same bus speed. it now compatible each other. if you want to put together one of two not show or not work even change in bios but actualy you can't change in bios setting...
Jun 11, 2009 | Toshiba Sattelite A105-S2071 Notebook
Compatability
The Kenwood TK-3200LU15 is the 2Watt replacment model for the TK-3101. the TK-3202 or TK-3203 are 4 watt models that can be used. Although, they have to be programmed with the frequencies and codes you are using. The TK3101 came with defualt GMRS/FRS frequencies.
HiTechWireless.com
Jan 14, 2009 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Expandability
Any of the FRS radios on the market should be able to communicate with your TalkAbouts. Most have the typical 14 or so FRS frequencies installed. Your T5410 has an interference eliminator, when set to anything other than zero, it will block out other users on your frequency. If you use this option, you will need to chose radios with this feature. Some of the cheaper off-brands do not offer it.
Aug 06, 2008 | Motorola T5410 (14 Channels) 2-Way Radio
Comaptible inks and original maufacturer product
Since quality is important to you, I would recommend staying with the OEM supplies. With compatible ink you could get early print head failure and you may not get the yield you expect, and end up spending the same amount of money. If you do go compatible, buy from a reputable supplier.
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Jensen JCS-600S (14 Channels) 2-Way Radio Logo
Top Jensen Radio Communications Experts
Mike Charette
Tom Chichester
Are you a Jensen Radio Communication Expert? Answer questions, earn points and help others
