Question about Cell Phones
Please help how do you change the ring tone on a mini touch phone
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
My office phone have a problem when customer call always complain i dont pick the phone but the problem is i dont hear the ringing tone please help
You can find detailed information about your phone from the given link below.
Panasonic KX-T7730
Check the steps below for "Does not Ring" solution.
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Panasonic KX-T7730 Corded Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
SINCE NEW , UNABLE TO CHANGE RING TONE. IT ONLY
Under settings menu touch, more, applications, voice command, call alert. Change to ring only. Hope this helps.
Aug 05, 2009 | LG Xenon GR500 Cell Phone
Volume on the phone/speaker/ring is very low
You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
May 24, 2009 | Innovage Speaker/Caller ID* LCD Touch...
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Setting up ring tone
When the phone is sitting in its normal mode hitting the "flash" button toggles through the available ring-tones, including my favorite: off
Jun 11, 2007 | Innovage Touch-panel Phone 1502084
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
